#29 |
I ordered the snow 210 stage 2 kit and using that gauge for my boost and % of injection. Getting everything installed in a couple weeks.
Race what you brung, Hope you brung enough
2016 2SS, NPP, Adrenaline Red Leather and Pads, 6sp, Sunroof, Black Bowties, Upgraded Wheels, 15% Tint, Kooks Headers, MBRP Exhaust, 1LE Wheels, Badging, Ported Throttle Body, Procharged, Snow Performance Stage 2 Meth Kit Coming Soon: Custom Cam, E85, Ported Heads |
#30 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Well, I'm confused... the damn cigarette lighter plug on my 16ss is hot all the time! I installed my gauge this weekend but had to Install a temporary switch under the dash as I couldn't find a switched wire and was running short on time.
Baby Blue
#31 |
![]() Drives: 2016 M6 Hyper Blue 2SS Join Date: May 2016
I plugged mine in the dome light where everyone hardwired their radar detectors. Check for the thread on how to hard wire a radar in the how to section.
16 2SS M6 // Kooks 1- 7/8 w/Off Road Pipes // RotoFab w/Oiled filter // Custom Axle Back Exhaust // E-85 Sensor // Tuned SOLD!!
#32 |
![]() Drives: 17 camaro ss Join Date: Mar 2018
The cluster needs to be reflashed as a ZL1 and you will have a factory boost gauge in your cluster
#33 |
![]() Drives: 2019 CTS-V Join Date: Feb 2016
#34 | |
![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
. Mine is a 16 also, and before I did mine I spoke with others that did the same thing I did with great success.
2018 ZL1…Many mods to come
#35 |
I'm thinking that maybe I just got a little impatient ...i searched for the cigarette lighter power wire with my volt/ohm meter with the 'key' on. When I located the wire and measured 12v, I pushed the key button to power everything off expecting my voltage reading to drop to zero. I know there is a several second delay for some accessories to power off, maybe I just didn't wait long enough. I'll check that out tonight.
Baby Blue
#36 |
I'm having engineer friend of a friend hook me up with a flash. It has to be specific to your car build is the problem. If you have a friend at a dealership they could do it if they know enough about the whole situation.
(Meaning you have to have you exact build then find part numbers for your specific cluster and two other parts. But they have a program to figure that stuff out I guess) |
#37 |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
I would think all you need is a gm mdi 2 with a susbscription to the sps programming website.
You would be looking to change the as-built data that is flashed into the instrument cluster. I own a gm mdi 2 and will log onto the gm website to see what kind of options are available for the DIY'ers like myself. I'd imagine the instrument cluster is the same; but flashed with a different operating system to show the additional gauge(s). keep you folks posted.
#38 | |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#39 | |
![]() Drives: 2016 Hyper Blue 2SS w/White Rallye Join Date: May 2016
Have you found out anything yet?
![]() Quote:
#40 |
Horsepower whisperer
Drives: Camaro Join Date: Jun 2017
Interested as well
#41 |
No Hope
I'm in on this too. Would be very cool to be able to use a factory boost gauge.
2016 Camaro 2SS - M6 | Hyper Blue Metallic | NPP | MRC | Sunroof | Navigation | Black Bow Ties | ACS Spoiler | Black Tail lights | ZL1 1LE 3rd Brake Light | Roto Fab CAI | Stainless Works Cat-Back | Black 1LE Wheels | Nitto NT555 G2's 285 Front 305 Rear
#42 |
Hey guys, my buddy looked into and still same thing needed the problem is finding a dealer that will do it. Essentially all your doing is telling your cluster that your car is a ZL1. I haven't found a dealer that will do and I haven't had a tuner look into it yet since I haven't completely decided what I'm doing with mine yet so nothing has even been bought and I'm really not worried about it yet.
Side note my buddy bought the P3 gauge for in the drivers vent with the analog set up and it works great so far. Its an actual reading with a vac tube and shows up as a digital read out. Looks good and you can read codes and I think like 20 - 30 other things on it( not 100% sure but its a good number things) |
