Old 09-15-2016, 04:36 PM   #29
TSloper
Drives: 2016 Camaro SS
Originally Posted by GreaseMonkey83 View Post
Do you have anything else done to the car or just the tune?
Primary cat deletes (part of original tune)
Rotofab (new with the E85 tune)
TSloper is offline   Reply With Quote
Old 09-15-2016, 07:20 PM   #30
JFM-jr
JFM-jr's Avatar
Where will the stock fuel system tap out? I'm thinking around the 460whp mark?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 09-16-2016, 04:40 PM   #31
TSloper
A quick update...
I am no longer using the Virtual Flex Fuel sensor to move to E85. I finally caught an event while logging that makes it a no go for me. After doing some research on what I saw I confirmed that the VFF sensor will prevent the ECM from going into PE mode while it is in the learning process. The real issue is that the learning process kicked in again without warning and led to a WOT blast without PE enrichment. This is not something you want to have happen when you aren't expecting it to.
The other issue is that there is absolutely no way to force a relearn if the composition value gets corrupted for some reason. You have to wait until you can top it off with enough fuel.
So I've gone to a straight E85 tune. I have all of the gas tables modified correctly as though the VFF was still working. Everything is looking spot on and I don't have to worry about intermittent behavior.
Injector PW is up to 5.7-5.8 msec at the top end. What is the limit power wise on a stock fuel system? I don't know. There is still room left in the injection window. The injection window is longer than just the intake stroke. For someone looking to stay with boltons E85 makes a lot of sense. If you are going past that definitely some upgrades are warranted if you want to stay with E85.
Tim
Old 09-16-2016, 11:20 PM   #32
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
Originally Posted by TSloper View Post
A quick update...
Tim
Awe hell, now what do I do....
Blk16SS is offline   Reply With Quote
Old 09-19-2016, 10:49 PM   #33
Sp00ner
Sp00ner's Avatar
Hmmm, E85 and HP Tuners... I feel like I've been down this road, long ago, in a Tupperware based car...
Sp00ner is offline   Reply With Quote
Old 09-25-2016, 10:33 PM   #34
Zxmustang
Drives: Corvette
You guys may want to give this guy a call. Hes been doing this on LS engines for years.
http://www.dedicatedmotorsports.com/...Kits_s/114.htm
Zxmustang is offline   Reply With Quote
