Old 10-19-2016, 07:18 PM   #29
irmb
Drives: Camaro SS
Originally Posted by locktyght View Post
I was actually asking BECAUSE I saw that you're running the 285 square, but you also said that some custom work was done. I have a set of zl1 5 spoke brights that I would like to run on track days, but will they fit 285's with no issue?
I *think* I've got 25m offset front and rear. it is equal offset front and rear. I went to a local wheel guy for this reason - i didnt trust myself to figure it out.
but it does work - and I can do a full tire rotation.
irmb is offline   Reply With Quote
Old 10-19-2016, 07:19 PM   #30
irmb
Drives: Camaro SS
And I was referring to this as well, but I see that the wheels are (4) rears, not 2 fronts, 2 rear.
i was told with mag ride you may need spacers in front - to fit the shocks. apparently these shocks stick out some how.
Old 10-19-2016, 07:27 PM   #31
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
MRC dampers having a bigger body diameter would not surprise me at all.
Norm
Old 10-19-2016, 10:00 PM   #32
locktyght
locktyght's Avatar
Drives: 2023 LT2 Redline
Norm
Thanks for the input, I'll just have to put em on and see what happens. I know the rears won't, they're wrapped in 315, which was damn close on the 5th gen
2015 1LE sold
2016 2SS sold
2023 LT2 Redline
locktyght is offline   Reply With Quote
Old 10-20-2016, 05:39 PM   #33
Camaroguy555
Drives: SUMMIT WHITE 2016 1SS NPP 6MT MRC
Okay, here is my experience. I have MRC. I bought 4 factory black 5 spoke wheels, the stock Gen 6 wheels. I put 285/35s on them and they contacted the spring perch in the front. I ordered 15mm "adapters" (they bolt to the studs and then have new studs attached, some stud cutting required) and now the wheel and tire clears without any rubbing and sits flush with the fender. I will be ordering rears because the car looks funny without. I have no fear running adapters on the track. Spacers are scary because they reduce the stud length.
https://www.motorsport-tech.com/4DCGI/switchmodel (these are incredible quality)
Camaroguy555 is offline   Reply With Quote
