Old 09-03-2016, 05:37 PM   #29
BravoMyles
BravoMyles's Avatar
Drives: Blue/Black 2017 1SS
Originally Posted by jrs580 View Post
Read read read. Twin screw always comes out on top with power under the curve.
https://whipplesuperchargers.com/ind...iew&page_id=14
So in that theory, a twin screw like the Maggie (I think?) would be able to make more power?
2017 1SS - Hyper Blue Metallic
Heads, Cam, e85, 3600 Stall, Full bolt-ons, MBRP exhaust
2010 2SS - Summit White - SOLD
CAI intake, Borla Atak axle-back (Summit xpipe resonator delete), custom ported TB, Texas Speed 1 7/8" LT Headers w/ Catless connections
Instagram: bravomyles
BravoMyles is offline   Reply With Quote
Old 09-18-2016, 08:41 AM   #30
MRREVINTO7
Drives: 14 1Le --14 chevy ss sedan 07shelby
I always walked down twin screw cars with my centrifugal blower cars .. My 3v 07 mustang trapped 136 pulled like freight train and my 14 1LE was good for 141 mph traps with Paxton novi setup so I never cared if you were out on me a car or 2 by 660ft I am coming for you ..I call twin screw cars ...,Victims cause in the end they loose and a lot of time on the street they don't hook cause they hit hard to early
MRREVINTO7 is offline   Reply With Quote
Old 07-28-2017, 06:43 AM   #31
Hyperlinkblue
Drives: 2017 1ss m6. Blue.....
I also will be going the cetri route. I like that they run cooler, some people disagree and maybe at 8 psi it wont matter much but if your cranking em up i feel they run cooler. Id like to see the difference between IAT's on identicle cars running indenticle boost. Also the term heat soak technically happens when the cars hot then you turn it off. Whens the cars running i believe its just considered higher IAT's. Back on toppic, with lower IAT's come more performance of course, i personally want to do a procharger matched with a lt4 fuel system on a flex fuel tune. That sounds fun.
Hyperlinkblue is offline   Reply With Quote
Old 07-28-2017, 07:54 AM   #32
DFW1LE
DFW1LE's Avatar
Aside from centri/PD decision, at what power level do you need to start worrying about piston ring failures (> 600 whp)??
It would seem to get there drop-in pistons and fuel system upgrade and a good tune is needed to stay safe, unless your content with lower power #s.
Old 07-28-2017, 01:57 PM   #33
Hyperlinkblue
Problem is when does it stop. While the motor is out why not do the rods also? And also cam and heads etc. Good question about the rings, thats anyone's guess. I think at 600whp your safe. People have went above that by quite a bit allready.
