#29 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
If it's just plastic tabs holding it the hopefully I can spray wd40 and try to push/pry the tabs while pulling. Last edited by Richard0nee; 08-19-2016 at 01:46 PM. |
#30 | |
![]() Drives: 2016 Camaro 1LT Join Date: Apr 2016
EDIT: To be clear, you are prying off the badge. You do not need to get at any of the tabs. I pulled from the left side (facing the vehicle). |
#31 | |
#32 |
Drives: 2016 Camaro 2SS 6M Nightfall Gray Join Date: May 2016
Just for fun today as I already plasti-dipped my bowties on the car, I checked what it would take to get the front bowtie off. With a flashlight I could see the clips, stuck my hand in where the hood latch is and pushed each clip with that hand while pulling gently from the outside with the other hand. It popped off pretty easy.
#33 |
I got my black bow ties and I read the thread. So far I got the prong on the left to detach and I have a small flathead screwdriver holding it from going back into place. Has anyone used a heat gun to soften the plastic? Anyone know if that would work?
#34 | |
Retired from Car mfrs....
#35 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I just did my front emblem. I tried the WD-40 and trim tool trick and it snapped 3 of the 4 rear clips but no harm no foul. I wasn't planning on every using it again anyway.
Did anyone else black bowtie not fit as snug? The original gold one had zero wiggle room. The black one wiggles just a touch. Not enough to worry me at all, but it doesn't fit as tightly as the original. Last edited by Eric SS; 12-16-2016 at 04:37 PM. |
#36 |
![]() Drives: 2016 SS 2SS Join Date: Dec 2016
I took my badge off while i had the front fascia off......Super tight fit and wasnt easy to remove even being able to get at the back of it.
