#29 |
![]() Drives: 2016 Mosaic Black Camaro 2SS Join Date: Nov 2015
Is turning AFM off an option?
2016 Camaro 2SS
#30 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
#31 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
#32 |
![]() Drives: 2015 Challenger SRT Join Date: Jan 2016
For comparison, here's a paddle shift view of the A8 in the Challenger:
https://youtu.be/dCliRKw02Ig So for those who think a non-DCT can't shift quick with the paddles, that's just not true. Also keep in mind this video is of a Scat Pack. The SRT and Hellcat actually shift a little faster than this because Scat Packs don't have the 120ms Track mode. Not bragging, boasting, or otherwise trolling. Just saying I don't see why this couldn't be improved with software/tuning. Mike |
#33 |
Drives: 2016 1SS 6spd stick MSRC Join Date: Jan 2016
Anyone who think the A8 is a great transmission, or thinks a torque converter can shift as fast as a DCT, needs to go drive a PDK for themselves and stop being a fan boy that relies on marketing material for their info. Every hypercar runs a DCT, and not one supercar runs a torque converter for a reason. If you can't shift, or don't want to, the A8 is a decent torque converter trans when left in drive 100% of the time. But, no one who has driven a PDK will ever say that the A8 is a great transmission, because it's not. That's why I was forced to order my 2016 1SS with a stick.
#34 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#35 | ||
Mike |
#36 | |
#37 | |
Mike |
#38 | |
![]() Drives: 2016 camaro 2ss summit white Join Date: Dec 2015
Hey
#39 |
Hey
I think the car war already began, let's not turn into another camaro vs. Mustang thing, can we say fight club...
#40 |
![]() Drives: 1968 Camaro SS 350 Join Date: Nov 2015
Every performance car has a limited slip. Also called positraction or traction lock. Many different names for the same thing
1968 Camaro SS 350 Lemans Blue
-350 10.4:1 comp, Edelbrock Etec 200 heads, Comp XR288HR cam,AED750dp worked, Tremec TKO 600, console gauges w/tic toc tach, Moser 12 bolt, 4 wheel Willwoods Hyper Blue 2SS/6 speed, NPP, MRC, Nav, 5LQ 6 piston brakes, Black split spoke, Magnuson 2300 Heartbeat Supercharger, Flowtie upper grill |
#41 |
145lb Powerlifter
Drives: 2013 Camaro 2SS RS LS3 Join Date: Jan 2014
Even in manual mode, you are not shifting the transmission. With an automatic, the transmission always shifts itself. The only way to eliminate that is to get a manual transmission. Paddle shifters will never be instantaneous because you're still not shifting, you're just sending an electronic signal that you want the transmission to shift itself now, then you have to wait for the trans to actually do it. Buying an automatic transmission and complaining that you can't shift it yourself is silly. There is no way to manually shift the A8 transmission. It's an oxymoron.
#42 |
![]() Drives: 2016 Camaro 1SS A8 Join Date: Jan 2016
Manual trans guy here. But the A8 is nice. Takes some getting used too manually shifting it. We were looking for track times so the A8 was the obvious answer.
