TireRack
Old 08-25-2010, 06:53 PM   #29
SShift
SShift's Avatar
Drives: Only Bowties!
Great work!
SShift is offline   Reply With Quote
Old 08-25-2010, 07:18 PM   #30
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
These pipes are 28 inches of 2.25 tubing. The result retains some growl up to about 1400 RPM then it just stops.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 08-25-2010, 07:47 PM   #31
SSizzle
SSizzle's Avatar
Drives: Inferno Orange 2010 Camaro 2SS
Originally Posted by BigRed585Lbs View Post
Simply put, the formula for determining the length of a Helmholtz chamber used to knock out a drone frequency is:
1100 feet/second (roughly the speed of sound) divided by the target frequency you're trying to eliminate (in cycles/second) gives a full wavelength in feet per cycle. Divide this number by 4 to get a quarter wavelength (a much more convenient length to work with). Finally, multiply this wavelength by 12 to get the chamber length in inches.
Tap this length of pipe into the exhaust tube, making sure the other end of the pipe is capped off, and you have a Helmholtz chamber that takes the annoying frequency and bounces it back into the flow 180 degrees out of phase, knocking it out. The results: no more drone.
Right why didn't I think of that?!
SSizzle is offline   Reply With Quote
Old 08-26-2010, 08:29 AM   #32
zepcom
Zeta Brother to Camaro
zepcom's Avatar
Drives: 2009 Pontiac G8 GT
J-pipes at their finest. Nice work, OP.
Makes me think back to December 09 when I was frustrated until I found the secret J-pipe solution. I worked with BigRed585 and SOLO, and finally solved the drone problem on my car!
--zepcom
2009 Pontiac G8 GT
SOLO Performance HF-Cats &
SOLO Mach Unbalanced Catback with drone-free J-pipes
zepcom is offline   Reply With Quote
Old 08-26-2010, 10:17 AM   #33
BigRed585Lbs
Drives: Sierra and Tahoe
Had some fun with that one, didn't we!!!!
Oh, the sound; the sound!
BigRed585Lbs is offline   Reply With Quote
Old 08-26-2010, 10:25 AM   #34
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
dunno..getting used to the droan..
2010SLVRBULIT is offline   Reply With Quote
Old 08-26-2010, 11:05 AM   #35
Frank Castle
Frank Castle's Avatar
Drives: 2010 Camaro SS
When I first looked at that I thought to myself no freakin way I'm doing that, but compared to getting $500-$600 x-pipes that seems the way to go.
Frank Castle is offline   Reply With Quote
Old 08-26-2010, 12:15 PM   #36
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
I'll have to take a look at them when we meet up! Did it affect the sound at all other than eliminating the drone?
ssmike is offline   Reply With Quote
Old 08-26-2010, 12:30 PM   #37
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
Seems like it would work. But to dampen the sound and changing the harmonic frequency Could you bolt or weld on a heavy piece of metal.
At work turning a tube or pipe on a lathe we wrap or fill it with babbitrite (sawdust and oil looks like clay) or use rubber straps. This keeps it from vibrating or chatter (singing)
I would think you could do the same on the muffler But need to fire proof it.
skar is offline   Reply With Quote
Old 08-26-2010, 12:41 PM   #38
zepcom
zepcom's Avatar
At the time I installed them, I had their quietest g8 kit (that still had drone without the J pipes)... so thus the J's did make the overall system slightly quieter. Around the g8 trouble area (1760-2000 rpm) it got nearly too quiet at the time.
No worries though, my "pre-alpha; proof of concept" J's were improved upon by SOLO once they saw how well it worked... now all their J-bend solutions are fully adjustable and much better designed than the one I started with.
I now have an unbalanced system, (not sure if this is offered to the camaro guys or not) which gives a "dukes of hazard"-like lope to the exhaust note, quite pleasing in my opinion. Additionally, Since March I've had the HF Cats which add ~15% sound volume.
On my g8 (and yes, I hope we can get together soon, ssmike!) I think it sounds perfect. Loud and aggressive when 'getting on it', yet subdued and responsible when cruising or driving normally. When I say "subdued" ... I mean drone-free, as well as not too loud where you couldn't hold a conversation with someone else in the car and the radio being on. It's all good!
--zepcom
2009 Pontiac G8 GT
Old 08-26-2010, 01:19 PM   #39
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Unbalanced - does that mean 1 j-pipe is longer than the other? If so, I may go and play with the adjustments on mine.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 08-27-2010, 07:41 AM   #40
zepcom
zepcom's Avatar
J-pipes do more than dampen the sound. They elliminate it. Basically, since the J-pipes are sealed, consider them a "high pressure" area.
Let me back up a little bit here. Exhaust gasses are racing (excitedly) out to the end of your exhaust tips so they can reach the air, where the pressure is lower than where they came from (The combustion chamber and various exhaust components, actually!) ... so Exhaust gasses want to "get out" to an area of low pressure. Got it?
Okay, so since the J-pipes are sealed, no real "exhaust gasses" ever get into the J-pipes to begin with. To the exhaust gasses, the J-pipes are simply another wall that is not an option to exit from.
Sound waves are completely different. Sound waves can travel through just about anything... water, metal, etc. Sound waves are a byproduct of combustion engines. If you've ever heard "open headers" like on race cars or demo derby cars, you know what everything "really sounds like" right out of the combustion process. Normal factory stock exhaust systems are usually over-engineered to appease the 'transportation' type of person who does not like hearing engine noises. This is why enthusiasts upgrade to aftermarket exhaust components.
Drone is usually solved by a nearly silent stock exhaust system (over-engineered) ... and drone is the uncomfortable level of soundwaves, as they reverberate not only in the cabin but also in your eardrums.
What J-pipes do is allow the soundwaves to enter into the "mouth" of the J-pipes, and if you remember cosine/sine graphs from math class, you know what sound waves generally look like. Now the sound waves are inside this capped "tube" ... bouncing off each side in a certain pattern (Hertz rating) ... then BAM. they hit that cap at the end of the J-pipe. Now those sound waves are reflected in the exact opposite direction, in exactly the inverse wavelength pattern (effectively cancelling out that calculated soundwave pattern) and then at the "mouth" of the J-pipe, they safely exit back into the exhaust stream and out the rear of the car, now the inverse of what they were when they entered the J-pipe. The magic happens when the two inverses collide, within the J-pipe itself. This actually elliminates the sound that was calculated (or in other words, the exact overall length that you made the J-pipe).
If your calculation is wrong, you will not elliminate the sound.
This is completely different than "dampering" the metal to make the vibrations a different frequency, like you seemed to have suggested. While that works in some applications, the source of this drone is the engine itself, with it's specific engine harmonics. As soon as that stock exhaust system is replaced with a "performance" exhaust system, you get the nice rumble of a freer flowing exhaust system, however, now those engine harmonic traits (drone in certain RPM and engine load combination conditions) show their ugly head. J-pipes to the rescue!
That's the technology behind the J-pipes, in a nutshell. It works amazingly well, just a side effect of looking somewhat odd to someone who is expecting a muffler-looking apparatus under the rear of the car. They target the drone efficiently, without hardly any negative (silencing) of the performance exhaust sound that someone upgraded their exhaust system in order to hear. Win-win situation.
The proof of my claim of "high pressure area J-pipes" is that even after an hour of driving a J-pipe enabled car, the j-pipes themselves will be cool to the touch. This is because sound waves (only) are what enter and exit from the J-pipes, not exhaust gasses, and sound waves are independant of heat. Exhaust gasses, in contrast, contain a lot of heat, as the byproduct of the combustion process. Thus, be careful doing this test, as if you were to touch a part of the exhaust system that is NOT the J-pipe section after an hour of driving, you'd most definitely burn yourself. Don't say I didn't warn you!
Nope.
Unbalanced (as it pertains to the G8 offerings) means that there is no "connecting pipe" in front of the mid-muffler... meaning each separate bank of the car (side of the engine, consisting of 4 cylinders each) has it's own respective 'pulse' that goes through the muffler in an offset pattern. Compare this to using both hands at that "wack a mole" game, and offsetting each hand to be the opposite of the other. I know, stupid example. Anyways, at part throttle and idle conditions, these pulses are slightly noticable and are music to my ears. I do describe it as a "lope" similar to a mild cam sound would have. Slightly uneven offset of sound but not "misfire" or other bad issues. I compare to the dukes of hazard sound, if you've heard that, you have heard an offset or unbalanced exhaust system.
Both J-pipes are adjusted exactly the same. If one J-pipe was adjusted different than the other, the drone would only be 'half gone', in that only 1 j-pipe would be "tuned" to the correct frequency to cancel out the annoying drone, the other would be targeting a different frequency, and thus, would not be canceling out the troublesome drone.
Any other questions?
--zepcom
2009 Pontiac G8 GT
Old 08-27-2010, 09:16 AM   #41
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
Any exhaust companies planning on making such a thing for the Camaro?
Seems like there'd be a big market for it with all the droners out there.
Russell James is offline   Reply With Quote
Old 08-27-2010, 09:27 AM   #42
zepcom
zepcom's Avatar
Yes. SOLO Performance has J-pipe solutions. I think it's mainly for the V6 camaro crowd though. From what I've read, the V8 camaro catbacks do not drone (and don't have J-pipes either). I could be wrong...
--zepcom
2009 Pontiac G8 GT
Me vs 05 style gt 7CAMARO7 Chevy Camaro vs... 4 07-11-2009 03:31 AM
Congress Should Stop Giving GM Funds Supermans General Automotive + Other Cars Discussion 29 03-13-2009 10:07 AM
JUST STOP camarofanatic 5th Gen Camaro SS LS LT General Discussions 33 01-10-2009 07:16 PM
Stop Bitching. . . franknbeans 5th Gen Camaro SS LS LT General Discussions 108 10-30-2008 02:01 AM
Stripe Style jack24 Cosmetics and Lighting Modification Discussions 5 10-19-2008 09:41 PM
