Old 04-09-2019, 11:19 AM   #29
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Originally Posted by cbourbs View Post
Thanks!
I am also wondering with 325s on the front it they would trail allot on the highway. That might get a bit much to handle for long road trips
Where are you in Alberta?
Old 04-09-2019, 01:35 PM   #30
cbourbs
cbourbs's Avatar
Drives: 2019 ZL1 1LE
I'm on the south side of Edmonton
cbourbs is offline   Reply With Quote
Old 04-09-2019, 01:49 PM   #31
RSFR
RSFR's Avatar
Drives: ZL1
325s don't fit on the front, we tried it. We are able to run 355/30/19 Kumho V720 ACRs on the back after we removed the fender lining and tucked all the wiring harnesses away.
RSFR is offline   Reply With Quote
Old 04-09-2019, 02:18 PM   #32
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Depends on the 325 in question - the 325 Hoosier is about the size of the G3R 305. Narrower than the 325 G3R and the 315 R7.
Tried a 315 and 325/30/19 R7 on 19x11 +11 ZL1 1LE wheel at -2.7/-2.8 front camber on MRC struts (ground) with no spacer. DSSV's give more clearance.
First pic: 345 R7 (wider) vs. G3R, both on 12" ZL1 1LE wheels.
From another forum member: Mounted on 11" 305 G3R front vs. 315 R7 (wider) and 325 R7 (on 11.5" Z28 rim) vs. 325 G3R (wider - on 12" ZL1 1LE wheel).
I don't have a pic, but, the 325 R7 on an 11" was about dead nuts to the 305 G3R on a ZL1 1LE 11".
Of course, manufacturer variation will occur between them and within a tire run, but, just like from my drag racing days, Hoosier's specs are all over the map from reality on Tread Width, Section Width, Circumference, and Weight.
RUQWIKR is offline   Reply With Quote
Old 04-09-2019, 03:58 PM   #33
cbourbs
cbourbs's Avatar
I'm just looking for a street tire at this point. (I know you were just making the comparison of width)
I'm thinking if i can't fit a 325 on the front, i don't think I want to offset the width of front and back tire from stock by putting a 305 front and 345 rear.
I suppose i could go for a 315 in the front and 335 in the rear, however neither the supersport and or ps4s are available in those sizes.
MPS 4s with a 325 30 19 and 305 30 19 is the exact same as the stock goodyears.
Maybe it's worth burying the hatchet and going with the stock sizes in mps 4s since maybe going with something slightly bigger if i can find it might not be worth it due to the mps 4s being a better tire.
Old 04-11-2019, 12:45 PM   #34
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
When we talk about rubbing, are we talking about rubbing the suspension because the tires are too wide? Or are we talking about rubbing the fender because the tire got too tall due to not lowering the tire profile?
The ZL1 1LE tires already poke out (love it) so poking out further shouldn't be an issue.
So we should be able to run as wide as we want in the back as long as we have enough offset on the wheels? (I'm asking, not telling)
Fronts are a whole other story I'd imagine due to the fact that they turn haha.
I'm not a tire/wheel guru so just making sure I'm on the right page, thanks
Current: 2019 ZL1 1LE A10
Mods: MPS4s Tires | Borla Atak | CF Steering Wheel
Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500
angryBits is offline   Reply With Quote
Old 04-14-2019, 09:41 PM   #35
Getnlwr
Drives: '21 ZL1 A10 '08 SRT10
Originally Posted by URBAN LEGEND View Post
It’s priced low at tire rack. 286.13.
There is a reason they are cheap. It's not a bad reason. Just based around pricing issues. This size (345) is OEM on the dodge Viper. Granted most viper owners I know run a 355 instead because it fits the 13" wheel better. Mine runs a Pzero 355/30/19 because Tire rack had them at under @200 at one point.
Getnlwr is offline   Reply With Quote
Old 04-15-2019, 12:35 AM   #36
Scottyz
Scottyz's Avatar
Sorry if I’m misunderstanding this. Are you saying you are running a 355/30/19 tire on the stock ZL1 rear rim?
Old 05-01-2019, 09:16 AM   #37
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Here some more pics of the difference..
19x10.5 14mm offset 305s
19x11.0 38mm offset 345s
Old 05-01-2019, 09:25 AM   #38
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
I have interest in this MPSS. Anyone on these?
https://m.tirerack.com/tires/tires.j...omCompare1=yes
FYI, that MPSS has been replaced with the PS4S which is an even better tire. If they have stock left on the MPSS you may find a good deal on iy somewhere.
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 05-01-2019, 09:35 AM   #39
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Ya if rain and 30,000 miles are your number 1 priority...
I'd take the cup2 cup2 Nspec 1st..
Old 11-16-2020, 07:27 PM   #40
19 2SS
Drives: 2019 camaro 2ss
Are the rear zl1 fenders the same as the ss rear fenders?
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
19 2SS is offline   Reply With Quote
Old 11-17-2020, 07:34 AM   #41
FalconerOneSeven
FalconerOneSeven's Avatar
Drives: ZL1
Pilot super sport 345/30/19 in the rear on a Zl1 non 1Le
FalconerOneSeven is offline   Reply With Quote
Old 11-18-2020, 04:34 PM   #42
URBAN LEGEND
URBAN LEGEND's Avatar
Whoever wasn’t aware of this years ago must have been in China.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
