Old 06-10-2020, 02:44 PM   #393
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Originally Posted by foshjowler View Post
I'm likely to try the new Falkens once these Rivals are done. There's an SSC driver in my club that's already bought them, so they'll be the guinea pig.
Keep us updated, please!
Apexit53, I think the thing about their tests is that it's a very different car and tire size than what we're using. So it's hard to tell how much the results can be generalized to all other cars/sizes. I think the Rivals are an odd case, because they feel so different (which is to say they don't feel at all), and like a lot more slip. So I think different drivers respond very differently to them.
TheRealJA105, thanks for pointing to that other thread! I hadn't seen that before. I might order a pair of those Ford bushings just to see if the fit in the stock brackets. If so, that's a good solution, I think.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 06-10-2020, 02:49 PM   #394
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
Yup! Miatas with double wishbones and lots of camber with the proper sized wheel for the tire doesn't translate well to us 3700lb guys with pinched front tires.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold
94boosted is offline   Reply With Quote
Old 06-11-2020, 08:02 AM   #395
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
its not just with our cars though. I felt that way when i was in STX and the bfg was new. it tested fast but then all nats podiums that year was bridgestones.
I just get skeptical lol
#53 F Street
2025 FS National Champion
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 06-11-2020, 11:46 AM   #396
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Please post up if you do. I think my solution is going to work, but those really look like they would be a better fit.
Old 06-11-2020, 01:40 PM   #397
toeout
Drives: 2019 1SS 1LE
Hello to everybody. If everything works out, I'm picking up a 2019 1LE later tonight and I have a couple of B-Street questions. It seems the MRR M755 wheels are a popular option for 19" wheels. Some of the wheels I've seen have +23 front, + 43 rear offset, while Proparts sells these wheels with +23 front, +38 rear. Would there be any reason to have the rear wheels stick out 5mm more?
toeout is offline   Reply With Quote
Old 06-11-2020, 02:38 PM   #398
apexit53
apexit53's Avatar
need more rear lateral grip? Id just do with then +43 for the rear.
I have the same setup and run a 3mm spacer up front.
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 06-12-2020, 05:26 AM   #399
Ummpwr
Drives: Honda S2000
I'm running 19s with 305/325 supercar 3s on my 2018 SS1LE. They might be slightly slower than re71s but I'm hopefully they last longer and are more heat resilient when I use them for track days.
Eric
Ummpwr is offline   Reply With Quote
Old 06-12-2020, 05:29 AM   #400
Ummpwr
Drives: Honda S2000
Pics
Old 06-12-2020, 08:21 AM   #401
AustinTXracer
Drives: 20 SS 1LE
Eric
Nice - that's what I am considering. Anyone nearby with the 305 RE71R setup that you could swap wheels with for comparison? Would be really good info.
John Hale
multi time solo nats runner up :(
AustinTXracer is offline   Reply With Quote
Old 06-12-2020, 09:46 AM   #402
94boosted
94boosted's Avatar
Eric
That looks great. I really want to try that exact combo out back to back against square 305 RE71R's.
2017 - SS 1LE
Old 06-15-2020, 10:52 AM   #403
AustinTXracer
Drives: 20 SS 1LE
Took the new car out in totally stock form. Such a fun car! I had way too much fun with the skinny pedal and the results showed - lots of senseless hooning in my vid. I was 12th in PAX out of 146, but at least Vivek Goel got it up to 2nd place in the later runs!
My vid: https://youtu.be/SagEfQYpRKs
Vivek's vid: https://youtu.be/aYEWFogoa4o
PAX results: https://axwaresystems.com/axorm/file...2-2020_pax.htm
John Hale
Old 06-15-2020, 08:14 PM   #404
apexit53
apexit53's Avatar
Great Lakes pro was this weekend and while I do a lot of spca solo events this was only my second pro! lol. This was a blast but dang I hate launching cars!!
left side
right side
ended up 3rd in class, had a good run to maybe take 1st but conned it. Made it into the super challenge and coned my first round run away as well. This car is wider than a type r.... lol
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 06-15-2020, 08:19 PM   #405
Ummpwr
Drives: Honda S2000
Did another autox on the 305/325 Goodyear supercar 3 combo. I like it a lot. I'm still getting a little under steer on very tight turns. I co drive with my wife, it was about 80deg and we were basically hot lapping it (6 runs each driver,12 total in a row, no water). The tires never overheated. They were good enough for 1st in class 6th raw and 5th pax out of 64
Old 06-15-2020, 08:20 PM   #406
Ummpwr
Drives: Honda S2000
P.s. 8 of the top 10 raw were Chevy v8s
Marty Bull was actually in a c5z06
And the exocet has a ls1
