Old 08-09-2023, 11:41 AM   #365
cjperformance
cjperformance's Avatar
Originally Posted by BlackbeastSS2 View Post
In regards to choice, do what “you” feels best for your situation/budget. I think it’s great that everyone puts their two cents in on different builds. Just imagine if everyone showed up with the same cookie cutter builds or if everyone had the snobbish stock ZL1. Different strokes for different folks.
I dunno, I think most folks prefer 4-strokes
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 08-09-2023, 01:58 PM   #366
rcoe
rcoe's Avatar
Drives: 2016 Camaro SS
I really miss my 2 stroke bikes and quads.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Forged internals
BTR stage 3 cam - Circle Stage 3 trans
American Racing headers - Borla S-type
rcoe is offline   Reply With Quote
Old 08-11-2023, 04:17 PM   #367
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
The 3.0 is starting to show a lot of promise. Sure wish a certain guy would take his Camaro to the track.
OK...so finally got a day where it didn't rain, it was a private rental, and I didn't have work booked in advance....miracle lol. I really wanted to get some seat time in during a private rental to shake down the new 15" setup plus see how the new Whipple is doing. To be honest, where the 15" setup is not balanced (PK Auto thought the wheel weights would hit the brake caliper...they're probably right as there is virtually no clearance between the barrel and the caliper), I was worried about how bad vibration would be at the big end of the track. If anyone has a solution, I'm listening...! In any event, when I got there I realized it was really windy...in the wrong direction lol... probably not putting down any great numbers into a 15 MPH headwind and a 2400 DA, but I really needed some track time...so I'm glad I went anyway!
First run was a "half boost" shakedown (Smoothboost at half setting, ~800 WHP), so 10.77@139. And yes there was some vibration from the new 15's at the big end but I think it's livable (if not a little unsettling). Second run was a full boost 1/8 mile run which was 6.32@116 which is roughly a 9.8 run in the quarter... meh...
Next run was 9.60@146.5 which was a personal best ET for me surprisingly despite the low MPH. Followed that up with a 9.62@148. As the day got warmer and DA creeping even higher, the car actually got a bit quicker. Next to last run was 9.57@148 so another PB time.
For the last run I pulled the insulation gasket off the RotoFab BG (where it seals to the hood) to test a hunch. The car responded with a 9.56@149, which was a gain of .7 MPH which I thought was interesting. Not sure at what power level the BG is no longer optimum, but maybe I'm getting there.
So, TLDR: I still want to see if there is something I can do to balance the 15" setup. And I'm looking forward to fall and racing in a DA number that doesn't look like the National Debt...
Old 08-11-2023, 06:02 PM   #368
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Not bad! I would remove the RF filter and run the Bellmouth at track. It's probably worth a 30-50whp on your setup at the big end.
Old 08-11-2023, 06:16 PM   #369
Joshinator99
Moderator
Thanks! You’re probably right… I know the MAF table will need some work running that bell mouth but sounds like it’s well worth it.
Old 08-12-2023, 06:08 PM   #370
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
What was your EOI at around 1000ft and after on each run? You weren’t close to out of fuel maybe and as it got hotter your injection window got better possibly.
CamOnlyJabroni is offline   Reply With Quote
Old 08-12-2023, 08:09 PM   #371
Joshinator99
Moderator
I am getting close to the edge in fueling (5.7-5.9 IPW). I’ll have to take a look at EOI. Thanks for the help.
Old 08-12-2023, 10:31 PM   #372
CamOnlyJabroni
If it’s below 160-170 it’s down on power. With my +65’s I have just enough fuel on E55-E60 hitting 20psi. When my IPW’s are close to 6 my rail pressure is usually down 2-300 and my EOI is out of range.
Old 08-13-2023, 07:34 AM   #373
laynlo15
Drives: 2022 Lt1 A10
Congrats, making progress. Fall weather is coming so you'll continue to improve.
Old 08-13-2023, 07:53 AM   #374
Joshinator99
Moderator
Thank you both!
Old 08-14-2023, 08:37 AM   #375
Nmolina9239
Nmolina9239's Avatar
Drives: 2018 2SS
Nice work Josh! glad you found time with the crap wet summer we have been having up here.
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
Nmolina9239 is offline   Reply With Quote
Old 08-14-2023, 09:18 AM   #376
KingLT1
KingLT1's Avatar
His EOI is dipping in the 140's. Since Josh has the Fore low side, I suggested cranking the low side up to 85-90psi and the rail to 2500psi to see if that helps. Because right now he is on the edge with a lean afr of .86-87. If he can get the AFR to .84 and maintain a EOI above 150, I bet the car goes faster as is.
Old 08-14-2023, 04:11 PM   #377
Joshinator99
Moderator
Wow, so at 140 EOI that explains why I’m not trapping any faster despite adding 100 WHP…
I’ve got my prescription from Dr. King and need to get on it ASAP!
Old 08-14-2023, 04:15 PM   #378
Joshinator99
Moderator
Thanks! Even though I’ve got some more homework ahead of me to take that next step, it felt damn good to just go racing!
