Old 11-29-2017, 08:46 AM   #365
ModernCamaroZ28Fan
LT1_Radenso
ModernCamaroZ28Fan's Avatar
Drives: a 2 spd water bottle
Originally Posted by Red Chief View Post
I'm sure that render's in a very early state and the final product will be drastically improved but for now it brings to mind the 2018 Mustang refresh. That car looks like it like it was designed by an individual whose primary talent was being a personal friend of some corporate bigwig at Ford.
Dude, that comment was rude and I question if it is against the rules to offend someone. How dare you insult some who is only 5% finished of "modelling" requesting if he should contiune with some ford crap.
ModernCamaroZ28Fan is offline   Reply With Quote
Old 11-29-2017, 08:51 AM   #366
ModernCamaroZ28Fan
LT1_Radenso
Originally Posted by doc7000 View Post
There were technical reasons that left the L99 engine at 400BHP, the AFM setup they were running limited camshaft design to more conservative setups. It also limited the red line of the engine, these things were improved for the generation V SBC as the LT1 engine in the Corvette is rated at 460/465 and pulls to 6,500/6,600rpms from the factory.
That was Chevy before they let the Camaro Team take off. We will see in January or March. I think they will bump up the horsepower, and give it better tires, and options as well as 1LE and ZL1 advantages. Not 2 sure about weight, maybe next generation.
Old 11-29-2017, 12:14 PM   #367
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
Slight overreaction... lol
Cgocifer is offline   Reply With Quote
Old 11-29-2017, 12:43 PM   #368
gringo
gringo's Avatar
Drives: Camaro V6
The real reasons were probably emissions and CAFE. The L99 was detuned for the LS3 which was the hot power setup on the 5th gen. So, they restricted it by offering it with only the manual transmission sans AFM or VVT.
With the new direct injected LT1, no compromise engine options were needed. The cam and VVT could be optimized for maximum power. The new AFM setup along with the 8sp auto brought MPG targets up where they needed to be without sacrificing HP.
gringo is offline   Reply With Quote
Old 11-29-2017, 04:53 PM   #369
doc7000
Drives: 2004 Pontiac Grand Prix
No, there was an article about the L99 and it was talked about that the limiting factor was the AFM system at the time had limits cams as well as rpms.
http://www.superchevy.com/how-to/eng...an-l99-camaro/
Here is one reference from one article about the AFM lifters on the L99.
"Unlike a "typical" LS3 cam swap, the VVT camshaft system requires builders to remove the factory Active Fuel Management (AFM) lifters. These lifters just can't handle the lift of an aggressive camshaft, and must be swapped for a set of Comp Cams supplied hydraulic roller units. This means the cylinder heads have to come off"
The AFM system on the L99 used lifters that couldn't handle more aggressive camshafts and also limited rpms further so this limited the horsepower rating and rpm range of the L99 engine compared to the LS3.
doc7000 is offline   Reply With Quote
Old 11-29-2017, 05:00 PM   #370
Subcool
Drives: 2022 SS 1LE
I seriously doubt Chevy will bump camaro h.p. Without bumping the base corvette first.
Subcool is offline   Reply With Quote
Old 11-29-2017, 09:06 PM   #371
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Old AFM is history.
Look for the LT2 with more power (near 500hp) and new skip-fire AFM along with new lifters and other valvetrain hardware.
Possibly in the 2019 Camaro SS (we'll know soon), definitely in the 2020 Corvette (C8)
i
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 11-29-2017, 10:35 PM   #372
Cgocifer
Cgocifer's Avatar
Originally Posted by camaro5 View Post
Old AFM is history.
i
Interesting
Old 11-29-2017, 10:55 PM   #373
JaxChris
I am curious how they would apply this dynamic deactivation to performance applications. Too many are annoyed by AFM drone now, but this new method would cause an uneven drone that will make it even more pronounced. Otherwise, it looks like a good system that could even be used to keep a cylinder deactivated when the ECU detects a single cylinder issue.
Old 11-30-2017, 07:55 AM   #374
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
Keep in mind that the team that engineers the Small Block V8 and the team that engineers Camaro are separate teams. In VERY close communication, but separate teams. Point being that the Camaro team does not develop the engines are implement new engine tech. The engine team, located about 40 miles away does that and works with the Camaro and Corvette teams to fine tune for their applications. So "letting the Camaro Team take off" is not the issue. "What tools are available from the wizards in Pontiac?" is the issue.
Now having said that, bumping it a few hp is, as most of you are well aware, something that can be done in the "fine tuning".
Old 11-30-2017, 09:14 AM   #375
ModernCamaroZ28Fan
LT1_Radenso
That's great. Still pretty confident about 465 Horses and Traction for drag.
Old 11-30-2017, 01:39 PM   #376
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Add 15hp/15torque,drop 25lbs and throw in the 10speed auto. That'll run like a champ.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 11-30-2017, 09:19 PM   #377
metros11
Drives: 2018 SS 1LE
Without a doubt.
metros11 is offline   Reply With Quote
Old 11-30-2017, 09:56 PM   #378
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
I think the GT500 going from iron block to aluminum was the only time a pony car got lighter within the same generation. Can't recall another instance. If anything, I would expect it to gain some weight with the (slightly) heavier A10 and the addition of port injection.
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
