Old 06-30-2023, 12:21 PM   #323
laynlo15
Drives: 2022 Lt1 A10
Originally Posted by adamjwilson View Post
Hopefully will have the second set of results soon. The shop was busy yesterday, so no time on the rollers, but I know they will get it done eventually. They know its not my daily driver, but they know its been a long journey for me with them. It started back last year with 200 miles on the car and a DSX E85 kit and header install, and it took off from there.
They know that Reliability is #1 for me, so they will probably turn it down some after they reach some peak numbers. I will post some more numbers once I get them.
Better get you some drag radials to run on the street. I run a 305-35-20 Nitto 555 R2. Wouldn't even consider running a street tire at my 707 power level. You'll be in the same boat, you won't be able to hook it till probably 60 mph. You don't want that thing over revving all the time trying to get over 750 rwhp to hook up.
Old 07-01-2023, 06:56 AM   #324
adamjwilson
Drives: 2022 Camaro 2SS A10
Any tire better than Nitto? Run flats?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 07-01-2023, 07:51 AM   #325
cjperformance
cjperformance's Avatar
Nitto 555R2 are good. Run flats are prob one if the worst for traction. Too stiff and hard.
Theres also the toyo r888r (not a DR) but ive never used them. Neither are going to give great wet traction though.
The Michelin as3+ were decent in rain and cold, but by far inadequate everywhere else compared to a DR.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 07-01-2023, 09:33 AM   #326
I had Toyo R888Rs, they grip all right in the dry but sound like a monster truck with offroad tires. The whine starts at 40-45 mph and gets more obnoxious as you accelerate. Some don't mind and drown it out with their catless long tube headers, but you may want to think twice if you're planning to take someone for a drive on occasion and have a conversation in the car.
Old 07-01-2023, 10:58 AM   #327
laynlo15
I think Nitto makes the best street/drag radial. I have 6k miles on mine, they are a good choice for applications.
Old 07-11-2023, 10:58 AM   #328
adamjwilson
OK... car went through the road tune yesterday and should hit the rollers with the new pulleys on soon.... back to the drag radials... looks like Nitto 555R2 are good. I know NOTHING about drag radials... how are they in wet roads? (I heard they were 'shitty'...lmao) I am moving to FL next month, so mostly driving car on weekends for fun on dry roads, but it can rain quickly in FL.
I just know I have to replace the run flats that came with the car for sure. Thoughts?
Old 07-13-2023, 06:35 AM   #329
adamjwilson
Shop snagged me a pair of brand new Nitto 555R2s for 7 bills for the rear... so that is good. Pulleys changed and waiting to be put on the rollers.....
Old 07-13-2023, 06:51 AM   #330
laynlo15
What size did you go with? I run the 305 35 20s for the street and 28x10 Hoosier for the track. The Nitto is not going to hook from a dig, no tire will with your power level or even mine at 707, but from a 40 to 50 roll they do pretty good depending on the pavement. Waiting to see some great numbers.
Old 07-13-2023, 07:12 AM   #331
adamjwilson
The shop got me 305's... that is what they said they use....
The run flats on the car now is having a hard time hooking up on the rollers (and they have traction stuff on them) He uses Mickey Thompson's on his C7 (which is way over 1000rwhp), but a lot of guys here use the Nittos on the Camaros.
There is a sweet Gen6 with the twin hellion kit on it with a 427 that is over 1000rwhp in the shop when I stopped by yesterday... dude has spent over $80k on that build.... too rich for me... haha
Old 07-14-2023, 07:03 AM   #332
adamjwilson
Update...finally got the car on the rollers:
850 rwhp/ 843 torque at 14 lbs of boost
turned it down to 832/822
I am happy with that for a street car. The tuner did make a comment though... "tuned for E, but you won't really gain the benefits of the E until E60. 93 and meth is more than enough at this point" Regardless.. I am running E in the car if its available in FL where I am moving too.
Old 07-14-2023, 07:07 AM   #333
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Solid numbers, congrats!
Old 07-14-2023, 09:05 AM   #334
laynlo15
Great numbers, not sure I agree with your tuner, you will be able to find plenty of E in Florida. I'd want that all day long compared to 93 and meth. Congrats, the 3.0 is doing a great job. Has anyone put the big sucker on the scales?
Old 07-14-2023, 09:19 AM   #335
adamjwilson
No... I don't plan on taking it to the track, so whatever a stock 2SS/A10 weighs is what it is...lol
I plan on running E as I thought the comment from the tuner was a tad strange, as all along I have told the shop the only reason I was using meth was for cooling and washing the valves... I will run a tank of 93 or better occasionally as well. Just another coyote eater hitting the road
Old 07-14-2023, 09:37 AM   #336
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The tuner is probably correct. Pump and Meth is similar octane as E40-50. E60-80 would still produce lower EGT's due to reduced cylinder temps on combustion and make more power. On a forged, lower compression setup like yours, you can run it either way. There is enough margin for error to survive higher cylinder temps and any potential cylinder distribution inconsistency from the meth system. There is just no way a nozzle injecting fluid ahead of the throttle body can properly atomize and evenly distribute to all cylinders like 8 high pressure injectors fogging directly into the chamber. That doesn't mean it don't work because it still does...just not ideal on stock piston LT1's.
On a tight ring gap engine with mediocre pistons and high compression such as the stock LT1, we have to keep the cylinder temps as low as possible and need fuel evenly distributed to all cylinders.
But you jumped that hurdle right from the start by upgrading the internals and lowering compression. So you are good to go. Should be a fun setup!!
