Old 11-24-2017, 10:47 PM   #323
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
GM will probably list the real 460hp instead of under rating it to make it look like the Corvette has more. still has 60 more lbft of torque then the mustang.
Old 11-24-2017, 11:23 PM   #324
doc7000
Drives: 2004 Pontiac Grand Prix
The 2018 Mustang GT is rated at 460BHP and 420ftlbs of torque while the Camaro SS is rated at 455BHP and 455ft-lbs so the Camaro has 35ft-lbs more.
doc7000 is offline   Reply With Quote
Old 11-24-2017, 11:34 PM   #325
JCunningham
Drives: 2017 2SS M6
o thought the mustang only had 400lbft. Chevy under rates the Camaro to 455hp 455 lbft to make the vette look like its got more power but they use the exact same motor. Corvette is rated at 460hp 465lbft
Old 11-24-2017, 11:40 PM   #326
doc7000
I highly doubt the claim that the Camaro is under rated, modern rating system standards involve third party testers and stricter control on what it means to be stock. Looking at the few Mustang GT dynos and varies Camaro SS dynos would put them about even when it comes to horsepower ratings.
Old 11-24-2017, 11:49 PM   #327
JCunningham
Drives: 2017 2SS M6
well how does the motor in the Camaro and the motor in the Vette have different ratings when they are the same motor.
I guess the air filter housing may make 5hp and 10lbft on the vette. You think so? GM is the one that releases the numbers and they can under rate if they want to. They have done it many time in the past. Id would think 5hp 10lbft could be + or - on the engine dyno per run.
Old 11-25-2017, 01:21 AM   #328
WhyUMad1LE
Drives: 17 SS 1LE
They have different exhaust/headers
Old 11-25-2017, 01:35 AM   #329
JCunningham
Drives: 2017 2SS M6
yep theres another
Old 11-25-2017, 09:32 PM   #330
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
I think the Camaro is slightly detuned is why the Vette has more. Also todays power rating I think are pretty accurate. Yesterdays power rating were underrated. Even the old 302 Z/28 was 295hp. Modern dynos show 320 something and mid 300s tq. The Chrysler Hemi said 425 HP. Modern Dynos show about 490-low 500 on rebuilt back to spec engines. The 454 Chevys show around 500hp. And with all that power the tires and transmissions used could only squeeze out low 13 runs. But after performance tuning and slicks they were running low 12s. Imagine those car engines if they had modern 6 or 8 spd trans. and modern tires.
Marty McFlew is offline   Reply With Quote
Old 11-25-2017, 10:25 PM   #331
metros11
Drives: 2018 SS 1LE
Originally Posted by wjones14 View Post
Since Chevy always responds to what Ford is doing with the Mustang, I'm sure the engineers have noted that the 5.0 is now at 460 hp. And even though the torque number is more important for acceleration, horsepower is used for bragging rights and selling cars.
Aside from the horsepower, I'm sure Chevy also noticed the optional digital gauge cluster in the Mustang. Chevy has the HUD, but Ford has that big 12" customizable cluster.
So slight horsepower bump and optional digital gauges seem like good places to start as far as non-cosmetic changes.
I was thinking the same thing. It'll either be 460hp to match the Vette, or the latter will get it's own power bump and the number for the Camaro will rise.
Not ruling out being de-tuned, but more likely different intake and exhaust bumping the power.
metros11 is offline   Reply With Quote
Old 11-25-2017, 10:39 PM   #332
JCunningham
Drives: 2017 2SS M6
i wish i could imagine a 1970 Chevelle with a LSX 454 and 6 speed in my garage right now.
Old 11-26-2017, 06:39 PM   #333
Quinten_33
Quinten_33's Avatar
Drives: Silverado
I hope the SS will get bumped up to 475hp/475lb-ft. , V6 bumped up 20 hp and 10lb-ft, and the 2.0T will get 290/305. The ZL1 doesn’t need a power bump but a smaller upper pulley wouldn’t hurt. I’m also interested in exhaust tuning as the turbo sounds like crap and the Mustang GT just got a gattling gun-like exhaust.
As people have mentioned, we could finally see the 2.0T 1LE, but what’s the point?. I’ve heard that the V6 1LE has too much grip or not enough power, so reduceing power makes no sense. Sure, it would weigh 3350lbs and can be tuned to outrun an M2, but the only thing that car could do well is run an autocross course.
Quinten_33 is offline   Reply With Quote
Old 11-26-2017, 06:52 PM   #334
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
The Mustang has shown to make 400-405 rwtq through the manual transmission compared to about 420 rwtq from an LT1 powered car.
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 11-26-2017, 06:59 PM   #335
Zeke.Malvo
Zeke.Malvo's Avatar
Chevy doesn't always respond. Chevy was happy leaving the automatic SS at 400 hp from '11-'15 while the Mustang continued to improve and out-power it with 412 hp, 420 hp, and 435 hp. It took them 4 years to respond with the '16. Will they go another 4 years?
Old 11-26-2017, 07:01 PM   #336
ULTRAZLS1
ULTRAZLS1's Avatar
Same dyno same day?
If not irrelevant comparison. Ive seen numbers lower and higher than that for both. Theres a dyno comparison to a 2015 right now on m6g showing 389 rwtq. Ive seen lt1 well into the 43x rwtq on some dynos.
They are ~30-35 tq apart just like the rating says.
Nobody likes that thread kinda funny. Resonator delete and better conditions and only 9 hp higher than expected for the ratings (which is nothing). That thread is the best evidence that the car is not under rated and its mostly crickets.
