02-10-2021, 08:28 AM | #309 |
Drives: 2019 Camaro SS 1LE Join Date: Jul 2020
Thank you very much!
02-10-2021, 03:07 PM | #310 |
i like your oil feed mod!
I'm curious about the oil pressure drop on these cars with turbo added...have you logged it? not like we use afm but i am retaining vvt for stage one so the thought crossed my mind. I may end up using a turbosmart OPR to regulate 40psi to the turbo...help out the system a bit. |
02-11-2021, 07:35 AM | #311 | |
Drives: Turbo 6.2 Join Date: Feb 2019
100% get rid of vvt if you are going FI. 100%. It works great for small power upgrades or NA combos. Once you start making big power, esp with turbo. It cost me my last motor.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
02-11-2021, 09:12 AM | #312 |
VVT needs to go bye bye with about any cam swap even NA. It's ok for bolt-on mild NA stuff but even more aggressive H/C cars benefit a ton by removing it all together. The cam phaser is just not designed to handle the increased valve train load and rpm from a cam that requires substantially more spring pressure to control the valves.
2016 NFG 1SS A8
02-11-2021, 09:36 AM | #313 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Here’s some good info for tuning out the VVT. https://youtu.be/NtBPWIXCBQA
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 02-11-2021 at 09:53 AM. |
02-11-2021, 10:16 AM | #314 |
Why didn't you get Pray's stage 3? You have been on Jorge's YT channel and seen the results. It will make as much or more power then the EL-C7 and drive better. The lockout kit for the stock phaser seems to work for most NA stuff.
2016 NFG 1SS A8
02-11-2021, 10:29 AM | #315 | |
Both guys Pray and Jorge’s channel great work and info. Once I get it in the car and after first tune from shop I will be jumping on a remote dyno for Pray to tune with E85.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
02-11-2021, 09:08 PM | #316 | |
The LME cover comes with an o-ring too so no rtv...and looks nice. https://latemodelengines.com/lme-bil...ont-cover.html In the mean time i just want to get the turbo system up and running soundly at low boost (going to kill me to not turn it up)...save up some cash for the next round of parts and build a motor on the side. |
02-11-2021, 09:17 PM | #317 | |
02-12-2021, 12:00 PM | #318 |
if you guys scroll back a couple pages, I have pics of the LME billet front cover I have. Its a really nice piece and sitting on the shelf waiting to be installed. Not only does it remove the bulky and heavy phaser with a single cam gear it but also looks sweet =].
Katech said a few more weeks on the oil pump.
02-12-2021, 01:17 PM | #319 | |
02-18-2021, 11:37 AM | #320 |
Katech emailed me that the oil pump is shipping. Finally.
Bought a new meth pump and changing hose. Cleaning up the brake booster / vac pump hoses More Heat protectant Break in oil. Br30 5w30 O2 sensor extensions and sensor for the turbo header. Ground strap Second garage heater lol Vac/boost dist block Msd 2step wire clean up New Plug wires
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 Last edited by Choda; 02-18-2021 at 11:49 AM. |
02-18-2021, 11:47 AM | #321 |
There is a ground strap thread for hot cranking slowness. Most use the water pump bolt and neg post by the fuse box.
Chevy has a ground from that to the engine already and I don’t want a ground strap on my water pump. I’m going from the front clip bolt/body to the back of the passenger head. I buzzed the paint off the body and underside of the head of the bolt.
02-18-2021, 12:04 PM | #322 | |
If you don't mind - once you finish the ground cable installation - could you post a couple of photos in my thread about hot cranking slowness? I'm hoping to keep that thread alive with fresh ideas and several different solutions for where and how to attach the ground cable. I know that there still are many people out there dealing with this. Thanks
