Old 05-16-2023, 08:45 PM   #295
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Good stuff Josh, wasn't your 2.9 in the mid 900 rwhp?
Thanks Greg! Yeah. Best run was 955 WHP after Kong porting with the 2.9. And that sucker was maxed out…it would take a 6 gallon batch of ice water and make it hot in one pass! IATs would climb 20+ degrees during a run even with the ice tank. Now at 1059 WHP with the 3.0 and I could do 3-4 runs on the ice tank and still not be hot. The efficiency and cooling improvements are unbelievable. So I gained 104 WHP on the same dyno using the same pulley combo. Tough to beat that.
Old 05-16-2023, 10:16 PM   #296
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Solid results!
Old 05-17-2023, 05:56 AM   #297
Joshinator99
Moderator
Solid results!
Old 05-17-2023, 08:58 AM   #298
adamjwilson
Drives: 2022 Camaro 2SS A10
Congrats Josh!
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 05-17-2023, 06:42 PM   #299
Joshinator99
Moderator
Originally Posted by adamjwilson View Post
Congrats Josh!
Old 05-17-2023, 07:01 PM   #300
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Nice Josh! Do any pulls with the smooth boost dialed down? Curious what you would see at the lowest setting. I’m at 650 now and no way am I going for more without a simple way to dial it down so I don’t blow the tires off trying to pass someone at 55mph. lol
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 05-17-2023, 07:57 PM   #301
Joshinator99
Moderator
I did mess around with the boost knob as I wanted to creep up on my fuel situation. I’ve been driving around on the street with the boost knob at 50% until I could double check everything on the dyno. At that setting I made 12 psi and 808 WHP. It seemed like about all I wanted to use on the street lol! Turning the knob up to 75% yielded 16 psi and 957 WHP. Full tilt was 18 and change pounds (and 6.5 IPW…!) …so we ended up dialing down to 90% on the knob which was 18 psi flat and 1059 WHP. I haven’t tried it recently, but when I first put in the Smoothboost, having the knob all the way down was like 3 or 4 psi of boost…which is probably where I SHOULD run on the street…
Hope that helps. I LOVE the Smoothboost. Hopefully I’ll be able to do boost by gear with it at some point down the road too.
Old 05-17-2023, 09:29 PM   #302
laynlo15
Drives: 2022 Lt1 A10
That's cool to have the boost controller, its just kinda expensive, my 707 is hard to control below 60 mph even on drag radials and my old Camaro at 850 was pretty dangerous. I'm actually just running my larger pulley on the street which is 677 rwhp and its still plenty fun and only 9.2 psi of boost, so very safe.
Old 05-19-2023, 02:46 AM   #303
Chrome383Z
Chrome383Z's Avatar
Awesome. This is on my mod list for sure!
Old 05-19-2023, 09:27 AM   #304
KingLT1
KingLT1's Avatar
The smooth boost seems pretty cool. The only issue I see with having an aggressive pulley combination and the smooth boost is you are just capping off the amount of peak boost. The tq is still going to come in very early and aggressive on the hit like a light switch vs using larger pulleys to slow down how fast the supercharger ramps up.
Old 05-19-2023, 01:34 PM   #305
laynlo15
I prefer running the larger pulley on the street, I've swapped them so many times at the track and on the dyno it just takes 5 minutes to switch them with my 1/4" battery power ratchet, I never even have to release the tensioner during the swap. One man band. Its still very aggressive even with the larger pulley but so much fun. Just can't take the traction control off.
Old 06-14-2023, 05:15 PM   #306
Joshinator99
Moderator
Saw an interesting comment today from a Whipple employee on LSX Magazine. Looks like the days of 18K max blower RPM for Whipple blowers in cars is gone with the new rotor pack thankfully. Good to know I can dial this bad boy up once I get some more fuel.
For the supercharger, we go by maximum supercharger input RPM to set a safe limit for those reaching for the sky. For our superchargers, 18,000 input RPM is max for sustained usage such as in a marine application where WOT can be for minutes at a time. In automotive racing applications, they can tolerate up to 22-24k for short bursts. To calculate blower input RPM, you divide the driven crank pulley diameter by the supercharger pulley diameter, then multiply that value by your peak engine speed. An example of this would be: (8.00/3.25)*7,500 = 18,462 input rpm,” Purciello says.
Old 06-14-2023, 05:18 PM   #307
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
Saw an interesting comment today from a Whipple employee on LSX Magazine. Looks like the days of 18K blower RPM for Whipple blowers in cars is gone thankfully. Good to know I can dial this bad boy up once I get some more fuel.
Makes me wonder if it has always been the same guidance where 18k is sustained RPM, but it could handle higher bursts for drag racing.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 06-14-2023, 05:26 PM   #308
Joshinator99
Moderator
I don’t think so since in a 5/3 rotor pack 18,000 RPM on the 5 rotor is 30,000 RPM on the 3 rotor (which is vaporized bearing dust at that level in sustained operation lol). With the 4/3 rotor pack, the small rotor is now 24,000 RPM which is sustainable within reason and can survive a short burst over that.
