Old 01-21-2025, 03:37 PM   #295
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by calypso50kid View Post
https://youtu.be/6XMIlasKtjw?feature=shared
This is what I’ve been dealing with, can’t really even get into the power band of the engine before it starts darting left or right. No real
Crown on this section of road. Gonna continue to go other things. Working on getting some toe links and lockouts along with camber lockout stuff from SPL to see if locking all that down helps
This looks like a tire issue.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-21-2025, 04:09 PM   #296
calypso50kid
Drives: 2018 zle, 03 cobra, 92 mustang lx
one of the things im changing as well, waiting on some goodyears to get delivered so i can mount them next week.
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm
https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8
2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles.
calypso50kid is offline   Reply With Quote
Old 01-22-2025, 07:49 AM   #297
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Great video showing the rear end under power.
Old 01-22-2025, 08:26 AM   #298
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Perfect video of this issue
YUP!!! That's it!!!
Please keep us posted on what you find. Tires are next for me.
'20 ZL1 Black "Fury"
Old 01-23-2025, 03:27 AM   #299
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Mine is a 2017 ZL1. How can I tell if it was updated? I brought it in for a battery wire recall in 2019 and it’s been going to a dealer for all its oil changes.
george is offline   Reply With Quote
Old 01-23-2025, 07:34 AM   #300
JANNETTYRACING
Someone physically has to connect the car to GM SPS and check.
Old 01-27-2025, 10:06 PM   #301
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Originally Posted by ZLElvira View Post
Torque and Brake vectoring is REAL... it even says it in the Performance Supplement Manual. TRUSTING that is giving up everything you know about how to drive and relying on the computers. Kinda like how F1 drivers have to rely upon the aero... stay safe and slow, and there isn't enough downforce to make the turn, yet speed up and hold the line and she will be planted every time.
Your post is very interesting. Because these menus and tables were on my HSV RHD ZL-1. I tried to use them, but they didn't work correctly it seemed. When Ted looked at it, he asked me if I had messed with them, which I hadn't cause I don't know shit about this type of thing. I haven't checked it since Ted's initial re-tune. They did some weird stuff with these 375 ZL-1s. I wonder if these tables were put on these cars down under for a reason. Or if the menu is there and HSV tried to manually insert tables. IDK. Just guessing but it does seem strange. Thank you for your post...
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
Bangkok_ZL1 is offline   Reply With Quote
Old 02-09-2025, 07:18 AM   #302
calypso50kid
little update to my situation, mounted some new goodyear sc3 non R tires in 1le sizes. Similar results. Then went ahead and added some BMR toe arms with lockouts, had the car aligned, took them 6 hours on the rack. They could not get less then -3.5 degrees of camber on the driver side front, thought the car may have been hit. After spending several hours on it my self and the alignment shop owner agreed that we needed to move the cradle. Shifted the cradle and got the alignment into my specs. -2.7 front camber, 0 toe, -1.4 camber in rear with .2 of total toe in the back. Couldnt really get on it much after as it had rained while the car was on the rack but found a dry stretch of freeway it seems to have fixed the issue while in 4th gear at least. Need to get out once this weeks weather gets better and try some more acceleration with more favorable conditions.
To note, front toe when I came in was toed out and so was the rear, so this very well could have been alignment issues for this car.
