Old 05-15-2023, 11:33 AM   #281
clg82
Drives: 2020 Camaro ZL1
Magnuson is finally close. There might be information within the month.
Sooooooo it's been over a month, any news?
Old 05-15-2023, 11:45 AM   #282
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
CARB sent back more BS for them to answer, and wait - again...
Aren't we expecting an update from Josh soon? Was it this week, or next week, his hotrod was going in for tuning?
'20 ZL1 Black "Fury"
Old 05-15-2023, 11:58 AM   #283
clg82
Old 05-15-2023, 03:51 PM   #284
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I'm working on it! Sheesh! It took a few tries to get everything ironed out. The oil pressure "gauge" not reading was due to a wiring mishap back at the LT4 TMAP...completely unrelated (or so I thought lol). But both of those items are fixed. The cam position sensor had taken some damage after the belt break last fall so that got changed out. Then the new intercooler pump wiring was not right and kept cutting out, so that is now fixed. Then the alignment was way off after I tinkered with the BMR toe rods doing the 15" rear brake conversion...so I was dumping about $50 worth of rubber dust from my R888R's onto the rear bumper every time I drove it... So, all that is fixed, alignment is done, and heck I even got a state inspection sticker!
Dyno day is tomorrow (5/16)! I'm a little nervous...with the Smoothboost control set on 50% boost, I'm still getting 14+ pounds... full kill will be a bit silly I think and I doubt I have the high side fueling to pull that off. So we'll inch it up and watch the data logs. I'm nervous, but excited. Wish me luck! I'll report back in the evening...good or bad lol...
Old 05-16-2023, 06:18 AM   #285
adamjwilson
Drives: 2022 Camaro 2SS A10
Good Luck Josh! Post the results when you have them
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 05-16-2023, 07:14 AM   #286
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
+1! Good luck, and looking forward to you seeing the improvements you're looking for
Old 05-16-2023, 07:29 AM   #287
laynlo15
Drives: 2022 Lt1 A10
So that's today, no more excuses.
Old 05-16-2023, 12:56 PM   #288
Joshinator99
Moderator
So we’re all done…1059 WHP STD (1011 SAE) at 18 psi! Blower is at 19,000 RPM and I definitely think it’s got more in it but my high side fuel is tapped out. But for DI only I think that’s pretty darn good.
Edit: video clip of the run https://photos.app.goo.gl/xj1dCjgX74feNA439
Old 05-16-2023, 01:00 PM   #289
Nmolina9239
Nmolina9239's Avatar
Drives: 2018 2SS
Looks good Josh!!! What pulley combination did you make that on? I'm starting out with a 8.855 Lower and a 3.5 upper and go from there.
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
Nmolina9239 is offline   Reply With Quote
Old 05-16-2023, 01:29 PM   #290
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
CONGRATS!!!
It looks like the pulley info's on the bottom of the dyno graph.
Old 05-16-2023, 03:04 PM   #291
ZL14ever
Drives: 2018 Camaro ZL1 A10
Congrats. Did you check the logs for any indication of belt slip? 3.25" upper is probably considered too small in Whipple world and causes belt slip at this supercharger rpm
ZL14ever is offline   Reply With Quote
Old 05-16-2023, 04:23 PM   #292
Joshinator99
Moderator
Thanks!
No evidence of belt slip at all and I didn’t have a problem with that pulley combo on my old 2.9 either. I do run the TooHighPSI LT5 tensioner setup and run the belt on the tight side too. Edit: also, I always run Griptec uppers too
Old 05-16-2023, 04:27 PM   #293
Joshinator99
Moderator
CONGRATS!!!
Thanks gentlemen! Rad is correct, pulley combo is 9.25/3.25 for about 19,000 RPM in my setup. It’s a fairly aggressive starting point lol The blower seems capable of more…I just need more fuel!
@Nmolina: I think an 8.855/3.5 combo will be fine to get things worked out. Once you’ve got it all dialed in you can drop down to the 3.25 upper down the road if you need more.
Old 05-16-2023, 08:24 PM   #294
laynlo15
Good stuff Josh, wasn't your 2.9 in the mid 900 rwhp?
