#281 |
![]() Drives: 17 Camaro lt, 22 Camaro LT1 Join Date: Nov 2016
![]() Got another time! I was able to duplicate this 4.6 run 3 times but can't seem to break it. Only different mods from the last best 0-60 is a boostalator and 40* outside temps. |
#282 |
![]() Drives: 2017 2LT RS Join Date: Nov 2018
Does everybody start from two pedals since 2.0T has no launch control? I heard start from 2 pedals could cause transmission damage, is it true?
#283 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
Only way that's causing transmission damage is if the transmission already had issues. Doing a hard launch over 3k usually only results in spinning anyway.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
#284 |
Drives: 2019 Chevrolet Camaro 1LT 2.0T Join Date: Mar 2019
2019 M6, stock.
I have struggled to break 5.6s but today it finally hooked up...a 5.4s run, stock! Well, unless you count spark plugs and gap being different from factory. I think that there is some time to improve, as well. I had almost no wheel spin. |
#285 |
When I had my RaceChip GTS installed I ran a 5.1, but at that time was running 5.8+ stock. I have better control of the car and the temps are more optimal right now than they were a month ago when I was trying. I think sub-5 is realistic with the JacFab valve and the RaceChip, when they’re done updating it.
#286 | |
603 Camaros
#287 | |
#288 |
603 Camaros
Are you hard launching or 2k rpm launching?
#289 |
Can you define those for me?
What I’ve found to work best is to rev to about 2500-3000 rpm and then not quite drop the clutch but release pretty quickly. A full drop usually results in a bit too much wheel spin. What I’ve noticed is key is to not rev to 2500-3000 and spend any time waiting. Boost builds nicely at that level but falls off fairly quickly if you wait. |
#290 | |
HD Cooling and Brakes, Ingen Evo7300, ZZP Throttle Body, and Mishimoto Cat-Back w/ Quad Tips.
#291 |
Just realized that I could have been using NLS. That should take a tenth or two off, shouldnt it?
#292 |
603 Camaros
Updated sorry for the long delay.
#293 |
![]() Drives: Chevy Camaro Join Date: May 2019
I have a 2019 I4 turbo but it doesn’t have the 0-60 timer. I guess you could activate the speed limiter and use the timer, but that won’t be very accurate. Is there some way to add 0-60 timer, am I missing something?
#294 |
