Old 04-07-2026, 01:07 PM   #15
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Great find! That could really be a game changer! For sure help a lot of people that don't want to do the full port plate with 8 fuel injector route. Really cool!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 04-16-2026, 03:20 PM   #16
Katech_Mike
Drives: 2015 Camaro ZL1
We installed a Wisher kit this week. Worked very well and the support is excellent. H/C/X-port ZL1 made 820RWHP on full E85 without issue.
Katech_Mike is offline   Reply With Quote
Old 04-17-2026, 10:14 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Is that with the stock high side and an upgraded low side?
Old 04-17-2026, 10:38 AM   #18
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
This is promising news. Did you guys get before power measurements on the engine prior to installing the Wisher aux- jection set up?
758 HP/ 804 TQ
Old 04-17-2026, 07:51 PM   #19
ULTRAZLS1
ULTRAZLS1's Avatar
I’m taking my 2650 car to his shop on May 2nd for fitment on Magnuson cars. Says it will take about a week mostly for fuel line fitment.
So it won’t be long this will be available on Magnuson setups as well.
Old 04-17-2026, 08:01 PM   #20
ULTRAZLS1
ULTRAZLS1's Avatar
Fuel distribution is excellent he has all the data to back it up. Ryan totally backs this product. Nobody on the planet much better than him With the gen v LT1 platform. If he says it’s good. It’s good. IMO
1000 rwhp + supported I was told since I already have a stout DI setup , 38% cam, 50 injectors, aux pump etc etc.
Old 04-18-2026, 08:55 AM   #21
KingLT1
KingLT1's Avatar
Nice. He offered me to bring my car down to him for the Whipple, but I believe someone else tried the base LT4 setup and it fits the 3.0.
Old 04-18-2026, 10:47 AM   #22
ULTRAZLS1
ULTRAZLS1's Avatar
Yep I heard that too
Old 04-21-2026, 09:08 AM   #23
Katech_Mike
38% lobe, LT4 HPFP, and our new Stage 1 injectors. It didn't need the DI injectors but it had an aftermarket HPFP before that wasn't up to the task.
Old 04-21-2026, 09:09 AM   #24
Katech_Mike
Not really. Made 720RWHP before HPFP angle hit 130 and power fell off.
Old 04-21-2026, 09:14 AM   #25
Katech_Mike
I don't think it will go to 1,000RWHP unless the dyno is really happy.
We were already in the low 80's for DC at 820RWHP with 38% lobe, LT4 HPFP, Ect.
I think it's a great fueling option for ~900RWHP. It's a 1/4 of the cost of full port.
Old 04-21-2026, 11:57 AM   #26
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
38% lobe, LT4 HPFP, and our new Stage 1 injectors. I didn't need the DI injectors but it had an aftermarket HPFP before that wasn't up to the task.
Using your guys upgraded lowside as well?
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Old 04-21-2026, 03:11 PM   #27
Katech_Mike
This car has a DSX aux pump on it.
Old 04-21-2026, 03:57 PM   #28
Z OH 6
Drives: 2024 CT5-V Blackwing
So, is the consensus that this style of port injection won't do any harm to the supercharger? No risks, only benefits?
Z OH 6 is online now   Reply With Quote
