#15 | |
Moderator
#16 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
#17 |
Moderator
Sorry my car has been modded for so long I don’t remember much of the original setup lmao. The PCV lines from the valve covers to the OEM air/oil separator are still intact. The MM Wild uses a big (-10 or -12 AN options, I went with -12) line from the oil cap location on the valve covers to the MM Wild for direct communication with crankcase pressure. It also has a small vacuum line that allows the engine to pull through the catch can under typical use. But the big line is the emergency “blow off” if crankcase pressure builds up at all.
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
I get my facts from automotive forums and years of posts, not Google AI which is most certainly not correct many times.
#19 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Big Camaro power, even stock, I installed the Might Mouse regular catch can, had issues with a lot of oil but that was directly related to my valve covers not being fully baffled. I got the correct valve covers, upgraded the the MM 1000 Wild and LOVE how it performance at 800+ rwhp, and now will be more rwhp after I get my car back in a few week. Elite Catch cans seems to be nice was well. For this platform, it's dominated by Might Mouse and Elite.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#20 |
So looking around for MM pcv diagrams to try and understand how they are routing the system, it looks like there are 2 different methods. One leaves the stock pcv valve in place and one moves the pcv valve into the can itself. I know most of you guys dont really know how pcv actually works of even did the work on your own car. But someone that actually did, could you elaborate on the two different designs. Is it forced air gets one and N/A gets the other? Or does it come down to flow volume needs?
#21 | |
https://www.camaro6.com/forums/showthread.php?t=611982 Post #50 is the first Catch can I installed. Other posts further down you'll find the Mighty Mouse and the changes I made.
#22 | |
#23 | |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
Believe it's related to flow volume, or the power you're making. I have the mild with road course top which eliminates the top filter/breather and replaces it with a line that runs under the car. The road course top only works with the mild system and was told directly by MM should be good to 900 crank hp. This mild system replaces the stock pcv valve with their own which has a -6an line coming off it to the can. Then a line which runs to the throttle body I believe for vacuum, and a drain line coming off the bottom. Mine also has a line coming off the top with the road course top which runs to the bottom of the car with a little catch I made. The can has its own check valve like Josh said, so it runs back to the intake in most circumstances until pressure exceeds the check valve then vents out my line from the top, or filter in other setups. The road course top prevents oil from shooting out the filter on top if pressure got crazy and instead it would evacuate out the line going to the bottom into my catch. I've also replaced the stock line going from the stock air/oil separator to the intake with a -12an line I believe it is to help relieve crank case pressure as well.
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8 Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come... Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket 760 Whp / 700 Wtq E50 |
#24 | |
Does the valve open under any pressure? Or is it like a poppet valve that needs to be a specific pressure or higher? |
#25 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#26 | |
Moderator
#27 |
#28 |
Yeah, like the pressure that flows out of my engine at idle.
2020 ZL1LE A10.
