Old 01-05-2026, 06:21 PM   #15
almimono
Drives: 2010 camaro ss, 2024 Chevy Camaro 2
Originally Posted by VEEATE View Post
Hi all,
I cannot get a clear answer from my local IGLA installer or from the folks who make the Range AFM disabler. Simply stated:
In my 2021 stock LT1, can I have an IGLA system installed and also keep the Range AFM disabler active at all times? (The confusion lies in the fact that IGLA disables the OBD port to some degree, but not sure if it is to the point that the Range device will fail to work).
I will most appreciate replies based on actual experience, as I have already hear speculation for both yes and no.
I do not want to turn the IGLA off and on (in and out of service mode) in order to use the AFM disabler.
Thank you for your thoughts.
From my experience, the IGLA doesn’t interfere with the Range AFM disabler. both can stay active without having to toggle IGLA on/off. I’ve run them together with no issues
almimono is offline   Reply With Quote
Old 01-06-2026, 07:09 PM   #16
ShadowLT1
ShadowLT1's Avatar
Drives: 20' Camaro LT1
I have IGLA installed on my 2020 Camaro LT1 10 speed, and I use my AFM Range Disabler and works flawlessly. I also daily drive my car. It works perfectly fine. Car will auto start, and everything will work as if the IGLA was never installed. The only difference is, it will not allow you to throw it in any gears until you authorize the car.
ShadowLT1 is offline   Reply With Quote
