#15 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Even with snow tires, the car is ok at best. Granted the 6 isn't as strong as my SS, so you may do better than I would in snow. But I have snow tires on my car for winter, and if there's an inch of snow I ain't going anywhere. Especially in situations with inclined traffic lights or stop signs. To everyone else I used to live in Huntington, IN (North of Ft. Wayne) near where the OP does, and when he says they get snow, he's not talking 1-6 inches, he's talking 12-20+ inches.
#16 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
No Camaro is going to make it through 12-20" of unplowed snow, obviously. But neither is any other car: the limitation there is going to be ground clearance between the tires. I live in St. Louis, and I have driven my SS 1LE in 3" of unplowed snow multiple times on Conti DWS tires. It's fine, and the Snow/Ice mode does make it easier. On legit snow tires, there just shouldn't be a traction issue, although again the lack of any form of LSD isn't ideal.
Matt Miller
2020 SS 1LE |
#17 | |
![]() Drives: 2021 camaro 1ls Join Date: Nov 2020
#18 |
![]() Drives: 2018 Camaro RS 3.6 A8 Join Date: Jun 2018
Just turned 80,000 kms (50K miles) on my LGX. Other than the transmission shudder, which was fixed under warranty with the flush: Mobil 1 fluid replacing OEM Dexron VI, the only unscheduled repair was thermostat stuck open at 48K miles. Had the coolant temp sensor replaced at the same time since it's almost right next to it.
You'll need top of the line snow tires for normal winter driving, Michelin X-Ice or Bridgestone Blizzak, but don't bother with "performance" snow tires...with no LSD and low ground clearance, the car isn't up to the performance those much more expensive tires can deliver. And those tire are optimized for cold, dry roads. On snow-covered roads, the car will fishtail regardless of tires, unless trans is in snow/ice mode, which totally attenuates the throttle response, and the performance, as it should. I do drive mine in winter, but only if roads are dry and clear, easy to do with a bit of planning, so the all seasons (Pirelli PZero Nero), stay on year round. Did have the snows on for the first couple of years, but not since. |
