#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
The oem radius/tension arms seem much beefier than SPL. I may replace the rubber bush with a spherical though...
#16 |
![]() Drives: LT1 Join Date: Apr 2024
Are the rubber bushings stiffer on the FEA arms (compared to FE3)?
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I would think so. The ZLE has a lot more loading than an SS.
"KEEP THE FAITH"-Fbodfather |
#18 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
While I'm sure they are beefier in bending, those links only ever see tension and compression loads, so they don't need to be beefy in any other direction than that. That said, if a rock or other heavy object ever hits the tubular SPL link, it could ding it a lot easier than the stock solid aluminum piece, and that would render it much weaker, especially in compression. So for a long-term street-driven car, it makes sense for GM to use solid aluminum links.
Matt Miller
2020 SS 1LE |
#19 |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
SPL uses bearings not bushings. You also have an endless amount of adjustment over the stock arms. If you lower your car you'll need adjustable tie rod ends to eliminate bump steer.
