Old 07-17-2025, 11:46 AM   #15
clg82
Drives: 2020 Camaro ZL1
I had this issue after picking my car up from Katech this past spring. I even sent an email to Mike mentioned I noticed the had to crank over like 5 to 6 seconds before starting. Mike told me to check my battery voltage, and it was low. I charged the battery but still had the issue, but when checking the voltage it was still low. I put up with that for a few weeks and the battery finally totally died. Got a new battery and the car started perfectly like normal and ran fine!
What battery did Katech recommend?
Old 07-17-2025, 12:57 PM   #16
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Funny thing is, I purchased the exact replacement battery I had from the factory. But then, a day later ZLRob mentioned I should get a lithium. So I did, I order the Antigravity H6/Group-48 Lithium ($800). It's light as a feather (only half kidding), and it was fairly easy to installed! Well, only after I called Katech and they told me how to loosen and tighten the 10mm battery terminals !
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
2023_ZL1-AUTO is online now   Reply With Quote
Old 07-17-2025, 01:15 PM   #17
clg82
Funny thing is, I purchased the exact replacement battery I had from the factory. But then, a day later ZLRob mentioned I should get a lithium. So I did, I order the Antigravity H6/Group-48 Lithium ($800). It's light as a feather (only half kidding), and it was fairly was easy to installed! Well, only after I called Katech and they told me how to loosen and tighten the 10mm battery terminals !
You're catching on haha, I'm looking at those Antigravity batteries, they sure are pricey.
Which AMP hours did you go with?
Old 07-17-2025, 01:58 PM   #18
2023_ZL1-AUTO
Drives: 2023 ZL1
60Ah=1800 Cranking Amps
Old 07-18-2025, 09:02 AM   #19
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Seriously. My battery weighs what seems to be 30lbs or less. Helps for weight reduction too for the weight nerds who are into that sort of thing.
758 HP/ 804 TQ
