Old 07-25-2025, 09:47 AM   #15
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I am not going to get into a big pissin match over stock 93 tunes and K&N intakes but I know a few "good tuners" out there that have shared a lot of info with me over the years and none of them see that kind of power gain tune only on 93. The guys I trust see 8-10whp. I have been tuning since 2014 and I don't honestly believe there is that kind of power to be gained either. These engines come aggressively timed from the factory...they are not rich and the intake, exhaust flow really well (enough to support 500bhp easy).
You can make a dyno read anything. Make the stock pull heat soaked, then make the "tune only 93" pull cold, and voila...there is your big gain.
Spot on as usual my friend.
Old 07-25-2025, 03:22 PM   #16
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Old 07-28-2025, 09:26 AM   #17
ALMN
ALMN's Avatar
Drives: 2SS 1LE M6, Palisade Calligraphy
If you guys are done with your Bromance maybe with your experience you can provide an estimate whp and torque gain for the original post. Most of the people get pump and e tune on wideband. I am sure the dyno operators know how long to wait to minimize heat soak after and before each pull. I have been seeing so many standard corrected dynos on dyno jets. Even some reputable tuners do that. I would like to see SAE corrected and preferably on a mustang dyno. The delta before and even after tune can change when you are comparing STD to SAE corrected results as well. Anyways, thanks for the input guys!
ALMN is offline   Reply With Quote
Old 07-28-2025, 10:17 AM   #18
KingLT1
KingLT1's Avatar
I already did.
Old 07-28-2025, 12:01 PM   #19
6spdhyperblue
Drives: 2SS 1LE
Originally Posted by p47dman View Post
There is a slight difference in ID. Although the OEM tube has an expansion joint
right after the inlet that I believe would disturb airflow.
What does the k and n look like at the maf? Are there airflow straighteners like the oem?
Old 08-04-2025, 10:04 PM   #20
p47dman
Drives: 2024 Camaro 1SS
I will post pics when I get home for you.
p47dman is offline   Reply With Quote
Old 08-13-2025, 03:40 PM   #21
RedHotSS17
RedHotSS17's Avatar
Drives: 2017 Camaro Red Hot 2SS
Got it done and dyno'd, 427.9 whp accounting for the average drivetrain loss from all online sources (14.29%) 499.3 crank hp, wheel toque is 424.9 so 495.7 ft lb
RedHotSS17 is offline   Reply With Quote
Old 08-14-2025, 01:33 PM   #22
vince3
Drives: 2022 Vivid Orange LT1-M6
Any idea of what kind of dyno that is? Who did the tune?
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 08-15-2025, 09:11 AM   #23
RedHotSS17
RedHotSS17's Avatar
It says online, dual eddy current AWD (all-wheel drive) dyno
Old 08-15-2025, 09:52 AM   #24
ALMN
ALMN's Avatar
Attachment 1167207
Is this on pump gas 93 or 91 octane? What was the baseline on the same dyno before the headers? STD or SAE corrected?
Old 08-15-2025, 11:05 AM   #25
vince3
The peak is my concern, but dynos are different. Peak hp at 5278 seems off. I wonder if that is just how the dyno is set up, or the K&N's smaller tube is hurting peak.
