Old 03-17-2026, 06:35 PM   #15
cdb95z28
cdb95z28's Avatar
Originally Posted by wakespeak View Post
The new 2025 GT3RS's are wearing these Goodyears: Eagle F1 Supersport RS. 80 Treadwear tires. Trying to see if they come on the ZL1 1LE sizes. I did see them somewhere in 305/30/R19s but not the 325 rears.
Edit:
"*The Goodyear Eagle F1 SuperSport RS tyres are designed to be used exclusively on the Porsche 911 GT2 RS models and the Porsche 911 GT3 RS models (991 series) and must not be used on any other vehicle type, including other Porsche models."
Maybe they'll do a version for Camaros/Vettes.
I have a set of the SuperSport R's in 305/30-19. 80 TW but their grip was less than SC3R. They were early 2021 production and I got them from Ebay in 2024. Repsonse and steering feel was outstanding but they did not have grip of an 80TW tire. Wear was very good too, the shoulders took the abuse better than the SC3 or SC3R. Granted they are a European market tire that was made in Germany, so that TW rating may only be based on Goodyear's European tires. I still have them, gonna run them on the street. The more aggressive RS variant would be a great tire to try.
"KEEP THE FAITH"-Fbodfather
Old 03-19-2026, 10:41 PM   #16
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Attachment 1173569
Attachment 1173570
Attachment 1173571
Really interesting info thanks! Surprising you found them having less grip than the SC3R. Will look for the RS version in the right sizes.
wakespeak is offline   Reply With Quote
Old 03-20-2026, 04:24 AM   #17
cdb95z28
cdb95z28's Avatar
For contrast, I'll add that the weekend I tried them I also ran a new set of 305/30-19 3R's. Pitt Race. Saturday was a test session for me with new anti roll bars. I ran the SuperSport R. Ran a 1.57.
Previous events:OE 20" SC3 PB was 1.56.1. SC3 in 305/30-19 PB was a 1.54.9.
That evening I had the 3R's mounted on the same wheels. The next day was about the same ambients. First hot session I bested my PB at a 1.52.8.
Those SuperSport R felt like a Michelin Pilot Super Sport.
Old 03-25-2026, 01:43 PM   #18
Olemiss540
Drives: 2018 Camaro ZL1
Was the 3Rs in 305 or on the 20" wheels? Curious the 1.2s delta in 20" vs 19" wheels.
Olemiss540 is offline   Reply With Quote
Old 03-25-2026, 06:18 PM   #19
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
I ran SuperSportR in square 305/30/19. Compared to the 3R, the SSR were 2-3 seconds slower but lasted nearly 7 days. They were durable and highly communicative. I'd run them again if they were readily available and I got the same killer deal on Ebay as last time.
Very curious to see what the new SS RS is all about.
EDIT:
It seems the SSRS is not available in sizes that work for us. You can only get the SSR and even then, unsure of availability in the US.
https://www.goodyear.eu/en_gb/consum...upersport.html
Dabjbr is offline   Reply With Quote
Old 03-25-2026, 08:53 PM   #20
NG329
Drives: Chevrolet Camaro ZL1 1LE
Circling back on this thread. I ran both the Yoko AD09 at NJMP Lightning and touched a 1:13.09 lap which is the fastest I've ever gone on a street tire (usually 1:15.x). Prior to this event, my PB with scrubs was a 1:12.2. This past weekend tho, I set a new PB on Pirelli DH scrubs and ran a 1:11.43.
So I'm approximately 1.5 seconds off of my new PB on scrubs with the AD09 at NJMP Lightning. The 1:13 laps were no fluke because I touched it on more than one occasion.
Adding up all of my best splits for the Pirellis equaled a 1:10.4 lap time. The fastest splits for the AD09 added up to a 1:12.6.
I did not notice any discernible understeer with the AD09. In fact, I found them to be very responsive. They were able to maintain the pace for a good 20 minutes before fatigue set in. According to the AIM data, the AD09 lost ground in the high G section of turns 2-4. It was negligible everywhere else.
NG329 is offline   Reply With Quote
Old 03-28-2026, 05:57 PM   #21
NG329
AD09 vs Pirelli Scrubs
Old 03-28-2026, 06:34 PM   #22
wakespeak
wakespeak's Avatar
Looks like the SSR is comparable with a 200 tw tire. OK well mounting SC3Rs for Chin this weekend. Michelin Cup 2Rs anyone?
Old 03-28-2026, 07:59 PM   #23
cdb95z28
cdb95z28's Avatar
The 3Rs were 305/30-19 squared.
Old 04-19-2026, 01:45 PM   #24
1leAL73
1leAL73's Avatar
Drives: 2022 Chevrolet Camaro SS 1LE
These are my track attack pros after yesterday’s autocross. I’ve done 5 events on a cement surface and about 3000 street driven miles on them. The track alignment seems to wear on the inner side of the tire on both the front and rear first for me. I’m not sure if this is due my driving or what. This is my 2nd set of tires on the same settings that have worn the innner side first.
1leAL73 is offline   Reply With Quote
Old 04-20-2026, 01:36 PM   #25
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I have dialed my alignment to -2.5 front and -1.5 rear to best the wear on the TAP's at autoX with a combination of asphalt/concert. They're also tire air pressure sensitive and I've found they're not to be run at higher-than-other-tires pressure like Hoosier recommends in their tire guide - when I did run at those pressures I hit cords middle of the tire while the inner and outside still had lots of thread left. As for the alignment, it's a compromise of corner traction and wear.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 04-20-2026, 03:27 PM   #26
1leAL73
1leAL73's Avatar
Appreciate the feedback. I would start at 30 psi all around but would manage the pressure at 32 hot all around during the event. I think I wore out my tires prematurely because a combination of not managing heat well and aggressive camber settings with amateur level driving. Also I didn’t heat cycle them. I was thinking to reduce the camber to -2.3 Front and -1.5 Rear and then properly cool the tires after each run to make them last a bit longer. It was 80 degrees at event and that with the abrasive cement surface and a heavy car on r compound tires probably softened the surface of the tire which caused it to chunk off like that.
Old 04-30-2026, 05:36 PM   #27
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Hey all, so I started this thread about the AD09 a year back, and I have some updates. I have a year and 6.5 track days on these tires. Last year I ran them with an alignment issue I didn't catch, which lead to lower than expected corner grip, and me trying to compensate with too low hot pressures. I ran them down to 30psi hot in a few sessions at Pitt Race.
While the lower pressures helped get better grip, it also caused the outside shoulder to get excessively torn up.
I was at VIR last weekend for a full weekend event, and I loved the tire after fixing the alignment. It had very good grip, and more in reserve for when I enter into a corner too hot. Also gripped well at 34 all the up to 38 PSI. My opinion of the tire took a 180 turn after getting the alignment fixed. I will be getting another set.
The shoulders are now pretty torn up, so I need a new front set at least, as the rears are still ok. ~5000 street miles and 6.5 track days on these. Wear on center is quite good still, just barely on the wear bars.
But what do you think? Can I get 1 more track day on these before I see cords?
5.M0NSTER is offline   Reply With Quote
Old 04-30-2026, 08:54 PM   #28
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Curious about your thoughts compared to a Goodyear SC3 (not R) now that you've sorted out the alignment. The Goodyears are considerably cheaper in the OE sizes for an SS 1LE.
But what do you think? Can I get 1 more track day on these before I see cords?[/QUOTE]
Hard to say for sure without knowing what was fixed on your alignment and where it landed. If you have all the stock front camber (hopefully -2.7ish) and no toe or maybe a smidgeon of toe out, you might get away with one more track day on these. I'm no expert, but it looks like those maybe blistered. If so, I'd send it it: the rubber underneath could still be good. OTOH, if that's the last of the true tread compound showing through those holes, then it's not a great idea to use them any more for track work.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
