#15 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#16 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
#17 |
Wasn't much left to save, the front rotors are massive, the second biggest every fitted to a production vehicle, much bigger than the ZL1, and it has a 2.65L blower on top which weighs a good bit more than the ZL1's 1.7L blower. Between those two items and the cooling required to keep temps down for a track car, and bigger wheels than any other Mustang previously that's where the weight increases came from. They did offer carbon fiber wheels on the track pack though which only weigh 17lbs per wheel compared to 42lbs per wheel for the forged aluminum wheels.
#18 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Update: Got both halves removed from the car. Looks like the driveshaft was failing in a secondary forward of where it broke closer to the rear end flange. Now the decision, go with another Carbon Fiber DS, Aluminum DS or Molly DS ? My concern is with these drag radials (MT ET Street R's), is that too much grip/bite for the stock DS assembly? Something made the CF one fail, so I'm getting skittish about the whole thing at this point and what is going to last!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#19 | |
#20 |
Moderator
Agreed
#21 |
Z OH 6 & Joshinator99 - Thanks I'll consider this since I don't want my car back on a lift for this particular reason ever again !
#22 |
I have a vibration from about 3500rpms and up, believe ds was damaged same time my driverside stock 1/2 shaft failed. Swapped 1/2 shafts for Renegades no issues. Thinking molly way to go. Was pretty surprised at my power level that the stock stuff didn’t hold a 1.5 60’.
CSP 755 Package. 2” headers, Kong ported blower, NW103mm TB, RF Big Gulp, Mighty Mouse catch can.
630rwhp/660rwtq. |
#23 |
NOVAtwinLS3 - Interesting... I was also having vibration, never thought it could be linked to the driveshaft !!!! Very interesting !
#24 | |
#25 | |
The only questionable aspect here is the 20% drivetrain loss they calculated, which is exaggerated and not scientific (but then again, who can realistically expect shops to provide SAE certified ratings?)
#26 |
![]() Drives: '22 ZL1 A10 Join Date: Apr 2023
Might have been done on a Mustang Dyno... see my listing
'22 ZL1 A10 Riverside Blue Coupe
Katech 103 TB, RF Big Gulp, Katech Ported SC, Griptec 2.3" Upper, Kooks 1-7/8" LTH w/Long System+Green Cats, Brisk RR14S Plugs, Katech Race Wires+Plug Sleeves, DMS XL SC Heat Exchanger, ADM SC Expansion Tank, Katech 160*, CT5 BW Oversized Front Brake Air Deflectors, BMR Rear Cradle Lockout, JRE Oversized Crankcase Vent Hose, BMR Poly Motor Mounts, JXB Driveshaft Center Street Bushing Mount, Power Steering Air Deflectors, Katech ECM/TCM tuned; 630whp/612wtq on 93 octane (Mustang Dyno) |
#27 | |
#28 |
So if you watch the LMP YouTube videos... they talk about their 900hp build, go through what the mods are, show you the build, but never show the Dyno.. Probably because they are talking at the crank. So probably only 780rwhp or something like that. Florida High Performance, Eric talked about this briefly in one of his videos... He said: " our 1000HP package/840wheel"... or something like that.
