#15 | ||
Truth to be told in hindsight, Milwaukee is better across the board, but not by much, and who's gonna toss a whole deck of good tools for small improvements anyway, eh?
#16 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
clg82 - I'm obviously missing something here, you've made several comments about me taking my car to Katech and I have no clue why! But, I'll say it now since a few here already know! My ZL1 will be going back to Katech, I hope as soon as July, if not then this fall. When the work is done, it will have 4 digit rwhp numbers! Can't wait !!!
Life is good, when you drive a Camaro !
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#17 | |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
#18 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#19 | ||
Also, I promise I'll do everything I can to "NOT" put a 2650 on her! But, that depends on how many digits for one vs the other!!! Also, not critical, but I misplaced my GMS Hood Bracket Kit! I need another !!! I'm going to look fir it again tonight. But, if I can't find it, I'll text you ! Thanks
#20 |
![]() Drives: 2018 Cadillac CTS-V Join Date: Jul 2012
Great thread...
I'll add a few notes on my end: FI Interchiller helped a lot with the street/highway/canyon/40-roll MAT temps. I've got a stage 2 and after some initial installation headaches, the intercooler fluid temps will get to single digit numbers leaving MAT generally 15* less than ambient on a hot day while in competition mode and just about equal with ambient while the cabin is blowing cool air. Road course use... the only benefit here is helping the car to cool down in the pits. I've had to make sure I retained a large heat exchanger to last at the duration and load that a full course puts on these cars while pushing it for 20-30m straight. I've got a 2650 as well as a fender tank and a larger HE pushing only 15.5psi I ended up divorcing the oil system from the factory coolant albeit different than the GMS kit and replacing the aux heat exchanger. Never had a problem on the street, but on the road course I was seeing temps ~290* and the ECU was not happy as it tried to save things. With the separate system, the result was about a 30* lower temp on the track. I added back in an oil thermostat at 205* and it initially was keeping things at temp... but lately I've noted that the system is having a hard time getting up to temp unless I'm on track, so something I've got to look at there. New mystery. Engine coolant -- I got a Cold Case radiator and a 160* thermostat. On the street, I've never had an issue with temps. On the road course, I was blowing over and hitting above 260* which sucked. I've managed to find that drilling a few 1/8" holes in the thermostat was useful in controlling any flash temps that would otherwise kill the thermostat. On street right now my ECTs are right at 155*-165* on a 100* day. Maybe it creeps to 175* in traffic but drops with any motion. On the road course, 85* day (likely hotter on the track) WOT/Brake/Turn/WOT for 20m and I saw temps around 230*-ish. Success compared to the number of times the car complained about ECT temps and the ECU stepped in with pulling power. I've tried every thermostat out there Katech, MotoRad, Lingenfelter, stock, etc. The only thing to help is the old school hot rodder trick of drilling the holes (4 holes seems to be the sweet spot - leveraging the top weep hole as 1 and drilling 3 more). Takes a little bit longer to warm up but not too bad. I'd like to get a beefed up aux radiator to help the thermal shedding capability here. New Banks gauges are awesome! The alert features are GOLD esp when you're attention is paying attention to the apex, other cars on the track, braking points.. to be able to get your attention. The data logging also GOLD so everything I've mentioned is not anecdotal - I've pulled the data, plotted it, watched the way ECTs and MATs go from linear to exponential growth curves when at the limit. |
#21 |
As for the 160° thermostat compared to the factory one. Where is the benefit on lowering that? I've been confused on the factory vs 160°. I was told, not needed for street and drag strip, so it that more of a road course requirement?
Thanks!!!
#22 | |
On the street, assuming all is healthy, you don’t need to worry about it. Most pulls that would land you in jail on the street are likely 3-5s. Step on the gas pedal continuously for 10s at full boost and all the temps increase. If you’re not hitting thresholds, you’re golden. If you are, then you need to do something. On the road course, it’s brutal as things just get heat soaked. |
#23 |
![]() Drives: Camaro ZL1 Join Date: Jan 2025
#24 | |||
Petro-sexual
![]() Quote:
#25 |
Thanks and Thanks both of you guys... I added GMS (Gabe's) Hood Bracket just now !!! I'm sure it's going to be way better cooling for engine bay temps, especially at low cruising speeds/traffic. I'm amazed with how much HOT FLIPP'N air is now coming out of the opening the bracket made while my car idles! Holy Crap Batman ! I'm shocked!
#26 | |
.....how much extra did it open that opening, I am probably going to pull the trigger on this bracket since the maggie lid scuffed up the old support with my port injection....just waiting on the DSX lid to arrive, but I hate the unsightly scratches now.
#27 | |
I hear you on the scratches! I have some unsightly scratch's in my engine bay: 1) on the CAI frame support that holds the front fastener of the RotoFab BG, and 2) on the drivers side shock tower. UGH! Every time I open the hood, they just scream out, look here, scratches. I just need to fix them and move on! My original polished aluminum DSX lid also got scratched once when I removed it. I tried buffing them out, it ended up looking ok. But, I could still see the scratches slightly. So, I replaced it with the red one I have now! But, as far as how much more open the venting area is with the hood bracket installed, it's a lot! I'll measure it this evening (might have to brush up on my algebra!) But, from what I can tell, the factory insert and support frame off (I've removed and reinstalled mine twice in the past). It looked to me like the it's sealed all the way around excepts where the rain guard/deflector is at the front. I know when I'd wash my car, then only water in the engine bay was right at the opening of the rain guard. So, I'm not sure it's even considered an open area at all. Now, that the bracket's installed, I see daylight all the way around the opening, everywhere until the back/ corner intersection where the carbon fiber insert is bolted in place. After I installed the hood bracket, I washed my car. I place a plastic sheet over the entire engine bay area and closed the hood and washed. After I was done, I opened the hood and wow water was covering the plastic sheet everywhere. Again, the amount of heat that now comes out of the hood open where the insert is, is crazy! But, I'll measure later this evening. (<--- hint hint Gabe!)
#28 | |
