Old 05-30-2025, 11:18 AM   #15
RallyRunner
Drives: 2020 RG LT1 M6 / 2019 4runner
Originally Posted by cdrptrks View Post
Blackstone used oil analysis tests for my Camaro showed little difference in the physical properties (including TBN and fuel dilution %) between 5k mile and 7k mile oil change intervals and they actually recommended increasing my oil change interval to 9k miles!
while the reports are useful, do not depend on Blackstone to give you an accurate fuel dilution. they do not physically test for fuel dilution using gas chromatography, they use an algorithm based on the viscosity compared against your mileage. it is notoriously inaccurate on the conservative side.
give oil analyzers a try (sold through Amsoil), they use the correct physical test method. my street driven LT1 on a 5k mile change showed 1.5, and 1.7% fuel dilution on both tests i did with them through their reports. i've personally capped my changes at 6k miles max for this reason, even if viscosity is still in grade.
2020 LT1 | Rally Green + Ash Gray | Tremec | NPP | Sunroof
RallyRunner is offline   Reply With Quote
Old 05-30-2025, 02:22 PM   #16
DeuceCam
Drives: LT1
Originally Posted by Rich292 View Post
I’ve also seen a bunch of problems on oil filters with these cars. First there was the issues with putting the older style filter on (identical on the outside, but a different bypass valve pressure). That seems to have been resolved by clarifying that the PF64 is the right filter. But I can say I would not put that filter on my car in any circumstances.
There have been three variations on that filter over the years. There was the original that GM put on the C7 Corvettes that had some early engine failures. They said it was from flashing coming off the filter and going through the system. They changed the filters to a better design. Now they have changed the design again a few years ago (around 2021, which is when we started seeing more failures in the cars, interestingly enough). If you go look at a new PF64, the center hole has a flange around it. On every single one I’ve looked at, the flange is poorly made. There’s cracking around the flange opening, there’s metal shavings that are either sitting there or loose, or flashing that can come off. If that comes off, it’s on the clean side of the filter, and it can run through your engine and spin a bearing. And it will be totally random. Maybe the flashing doesn’t come off, maybe it gets pushed through the oiling to a benign part of the system and falls into the pan where the filter gets it, or maybe it goes to a bearing and spins it. I won’t use that style (a central spout style) on any of my cars.
Interesting. What oil filter do you use?
DeuceCam is offline   Reply With Quote
Old 05-30-2025, 02:36 PM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Do you have any evidence for these claims? Blackstone used oil analysis tests for my Camaro showed little difference in the physical properties (including TBN and fuel dilution %) between 5k mile and 7k mile oil change intervals and they actually recommended increasing my oil change interval to 9k miles!
I had Blackstone do a used oil analysis on a 7k mile oil change on my SS 1LE with unmodified engine (OLM showed 4% oil life remaining) with the original formula Mobil 1 ESP 0W-40 DexosR 2 oil including about 10 hours of track days. They said everything looked healthy and suggested trying a 9k mile oil change interval next time (but I didn't personally feel comfortable exceeding the OLM for warranty purposes). They found 0.5% fuel dilution vs. their maximum allowable recommendation of 1.9%.
I had them do another used oil analysis later with the newer formula Mobil 1 ESP X3 0W-40 at 5k miles including some track days and they suggested increasing the oil change interval to 7k miles with only a trace amount of fuel found and the viscosity, flashpoint, and TBN all being slightly higher than on the previous analysis.
I am not going to go spend a bunch of time pulling up info on it. Just spend a little time with your favorite search engine.
I have had a Whipple installed on my SS since 2019. Have run nothing but 5w30 Castrol Edge and K&N 1017 changed every 3k. Good luck with your 9k mile oil change interval's. Lmao
KingLT1 is online now   Reply With Quote
Old 05-30-2025, 04:57 PM   #18
Capricio
Drives: 2000 WS6
https://www.autoblog.com/news/gm-v8-...ecall-teardown
Skip to about 46:00 to hear him talk about comparisons with the LT1
Capricio is offline   Reply With Quote
Old 05-30-2025, 06:07 PM   #19
SS Lola
Drives: Gen 6 SS2 Camaro !LE
I have heard that 10-40 is being recommended now//? /supposedly oiling and engine issues with the 0-40? for gen 6 Camaro.
SS Lola is offline   Reply With Quote
Old 05-30-2025, 06:17 PM   #20
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Source?
Old 05-30-2025, 09:13 PM   #21
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Just use the damn supercar..
Shit like this makes me want to just sell the Camaro and get a Genesis.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 05-31-2025, 12:18 AM   #22
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
LOL!!!!
I used the euro 0W-40 in my ZL1-1LE since 2019 except when racing and its A-OK!!!! STILL!
GreenZLE is offline   Reply With Quote
Old 05-31-2025, 12:30 AM   #23
2SS Capt
2SS Capt's Avatar
I love it, people buy a $50k-$80K car and want to cheap out on oil changes... REALLY?!?!?!?! It's a $100-$150 oil change!!!! If you can't afford that, perhaps you should have considered a much less expensive vehicle because you are in WAY over your head...
Old 05-31-2025, 12:34 AM   #24
Rich292
Drives: 2015 Z/28
There are several oil filters that I think are good. The important thing is just to use a quality brand that you like and that does NOT have that little flange/spout type of center hole and that has the correct bypass valve rating (sometimes it's listed as 22 to 28 psi, sometimes 25 psi, but you need more than the older V8s that had a filter bypass at around 15 psi).
As far as the filters that I typically will use on my cars:
Purolator Boss 11403
Mobil 1 M1-114A
Fram - I know a lot of people don't like Fram because of the low end products, but their higher end filters are well made and test very well. I will use the Synthetic Endurance (Walmart exclusive), the Titanium (Advance Auto Parts exclusive), or the Ultra Synthetic. The series number is 12060.
Those are just what I like to use. Lots of people like other brands like Wix. The brands I use are mostly related to the products that I can find easily where I normally shop.
Rich292 is offline   Reply With Quote
Old 05-31-2025, 11:42 AM   #25
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
I used to run 5w30 until i found this case of 15w40 that someone was throwing out.
Old 05-31-2025, 11:54 AM   #26
beowulf556
Drives: 2023 ZL1 M6
Is this the supercar oil everyone is talking about? https://www.amazon.com/gp/product/B0...RN7J30K1&psc=1
2023 ZL1 M6 "Blueberry"
beowulf556 is offline   Reply With Quote
Old 05-31-2025, 11:57 AM   #27
Keko
Keko's Avatar
Drives: 2023 ZLE M6
it's generally not a good idea to increase the cold weight. all you are doing is increasing viscosity for cold starts to a range outside of what is expected
2023 ZLE M6
Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid
2024 Polestar 2 AWD
Keko is offline   Reply With Quote
Old 05-31-2025, 12:04 PM   #28
2SS Capt
2SS Capt's Avatar
Kind of, but you want the 0W-40 (your link is 5W-50)
oil, oil type
