#15 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
That is why spacers are necessary with 315's. Or the offset has to account for no spacers. And yes not all tires are created equal as well.
#16 | |
Anything outside of that is where you need to consider spacers, offset variance, and/or moving the wire harness. I thought the LT1's were 245 all the way around, but you can change that based on the screenshot I provided which means you'd have to change your wheel setup at the same time. But, you might be able to get away with putting 275/35R20 on the back on the stock wheel it depends on the actual wheel size. Normally the SS+ models have staggered wheel setups, so wider wheels on the back than front. I believe those are 9.5" wheels on the back @275/35R20. However our front wheels are 8.5" @245/40R20 I would check what your rear wheel width actually is before determining if you can put a wider tire on the back. Otherwise you may have to change out the rear wheels at minimum.
#17 | |
![]() Drives: 2024 2SS Camaro Nitro Yellow Met. Join Date: May 2020
Anytime, picking out the correct size tire can be pretty tricky, especially with all the various heights/widths of tires, then having to pick the correct wheel size with correct offset, just stick with the 1LE spec sizes, 20x10 +23 fronts, 20x11 +43 rears, 275/35/20 & 315/35/20 will fit perfectly, like 2SS Capt said moving the wire harness is super easy (even included pics of wire harness relocation), doesn't hurt to be a little cautious when it comes to that wire harness, better to be safe than sorry, than comes that time and you say, Damn wish I would've moved that harness. |
#18 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Wow, there's a LOT going on in this thread. The OP isn't interested in 35 series tires, and those are going to be way too tall for good fitment or cornering/braking performance, so that's a bad recommendation. 275s on 8.5" rim widths can physically be installed, but this is a bad idea. Within reason, tire width alone doesn't require spacers...IF you have the right offsets on your wheels.
The OP said he wants to emulate SS 1LE sizing, so this is a no-brainer: as a couple have said, he needs 20x10 et20 front wheels and 20x11 et43 rear wheels. Stock tire sizes are (again as noted) 285/30/20 and 305/30/20. There is no good reason to stray from that, either. They fit, and they work extremely well. There are also a lot of tires to choose from in these sizes. I emphatically would not recommend 275/30 in front and 315/30 in back. Aside from the fact that there's no good reason to do this, this sizing gives you a rear diameter that is 3.4% taller than the front. There's a good chance this will piss off the ABS/TCS and throw warning lights and cut power. We know you can get away with close to 3%, and I have done so by autocrossing a 275 and 305 combo. But a bigger difference than that is asking for trouble. Besides, there will be far fewer choices of tires in this size combo. You aren't going to cook your brakes because of the tires you choose. It'll be down to how you use them and what pads you use...and fluid. If you are really, truly using them hard (like HPDE lapping sessions), then an SS 1LE brake upgrade would be good. Otherwise, you will be fine with good pads and fluid. When it comes to actually choosing tires, if you really care about cornering and braking grip and you need tires that perform well in wet and/or cool conditions, then the only two to really consider are the Continental ExtremeContact Sport 02 and the Michelin Pilot Sport 4S. Of the two, I'd choose the Conti over the Michelin, but they are very close. These are both killer "three-season" tires, and they are the two best performing rain tires that are also true street tires. You can even use them safely for autocross and track day usage, although they won't be competitive with more competition-focused "street-but-not-really" tires. I don't know where you live and whether or not you drive the car in true winter conditions. If so, and if you don't want to swap wheels/tires for winter, then the Continental ExtremeContact DWS or Michelin Pilot Sport All Season 4 are the two to choose from. Again, they are extremely close in performance. I would honestly move the harness even if you go with with 305/30/20 in back. As other said, it's super easy and then you just know it won't be an issue. Feel free to ask follow-up questions!
Matt Miller
2020 SS 1LE |
#19 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#20 | |
![]() ![]() Drives: 2021 LT1 6spd Join Date: Nov 2020
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
#21 |
![]() Drives: LT1 Join Date: Mar 2022
#22 |
The fronts you can definitely upgrade, and they do 75% of the work anyway. The rears may be problematic because of the different parking brake setup, but I'm not very familiar with the details of the LT1 rear brake configuration.
#23 |
That is a good point Arpad... but at what point do we need to worry about flipping over the handlebars, like with a bike?
#24 | |
![]() ...but just in case this wasn't a joke, don't worry, there are no front brakes in existence, be them the SS 1LE or even the massive ZL1 1LE units that could stop the car fast enough to flip it. I think the max braking deceleration you can achieve is ~1.5 g, nowehere near enough to lift the rear of the car, plus you have ABS, plus the rear brakes do contribute some, this doesn't work like a bicycle.
#25 | ||
Matt Miller
2020 SS 1LE |
| Tags |
| lt1, lt1 wheels, ss 1le wheels |
