Old 05-19-2025, 08:14 PM   #15
Z OH 6
Drives: 2021 Red Hot ZL1
Originally Posted by SammYyYyY View Post
I know this topic has been beat to death, but from my understanding it solely comes down to whether you want to vent to atmosphere or not. If you are looking to have a road course car under 800 WHP, I've been told the E2X is the better choice as it can be dangerous to vent to atmosphere on a road course car, hence why this is what I'm going with.
However, if you want a 900+ WHP monster that is primarily a straight line car, I've been told using an MM-wild and venting to atmosphere is a better solution.
My engine builder was more familiar with the E2X setup so that's what I picked, but I don't think you can really go wrong with either. MM's support seemed much better from what I could tell.
Mighty Mouse makes a vented and unvented catch can, no reason to use E2X.
Old 05-19-2025, 08:32 PM   #16
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
100%. The MM Wild *only* vents to atmosphere if you’re experiencing crankcase pressure, which saves your seals from blowing out if you have a tune that is still being “finished” or you experience detonation. E2X is of no help IMO.
Joshinator99 is online now   Reply With Quote
Old 05-19-2025, 10:39 PM   #17
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
There is a road course top for the MM mild version which replaces the filter. The guy at MM told me he expects the mild version to be capable up to 900 hp. I assume that was crank HP. I've also added a bigger line going from the factory clean air separator to the intake to aid in excess crank pressure. The road course top adds a line to route under the car in case a bunch of oil blows out but still has the check valve to keep it sealed until a set pressure is reached.
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Old 05-19-2025, 10:41 PM   #18
AZIROC
Drives: '86 IROC-Z '18 ZL1
For MM...ill just say this. if you are drag racing or daily the car...get the wild. if you do HPDE/AUTOX then get the mild with recirculating top. DONT get the vented top or oil will spray all over your engine bay
Old 05-20-2025, 09:11 AM   #19
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
... I've also added a bigger line going from the factory clean air separator to the intake to aid in excess crank pressure...
Katech did the same for mine, larger hoses to the valve covers vents was well.
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
Old 05-20-2025, 10:32 AM   #20
Z OH 6
Yep, that's why I like MM, they make a proper catch can for different goals.
Old 05-20-2025, 11:13 AM   #21
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Is that will OEM or aftermarket valve covers?
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 05-20-2025, 11:25 AM   #22
2023_ZL1-AUTO
Keep in mind, the 6th Gens (Or at least the 2022-2023) ZL1 uses fully baffled valve covers from the factor. I had a MAJOR issue with my E2X CC and oil pooling up BADLY in my blower. The E2X was not not working well with the after market non-baffled valve covers I installed. I switched to MM 1000HP and with the same valve covers the oil issue was all but gone. I then went with fully baffled valve covers, and now I have ZERO issues related to CC and oil.
Old 05-20-2025, 02:31 PM   #23
JSH
JSH's Avatar
Drives: '20 ZLE
I only had a mighty mouse wild on mine until I blew out the rear seal. Then I put a breather cap on the oil fill neck
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 05-20-2025, 04:41 PM   #24
SammYyYyY
Drives: 2018 ZL1 1LE
From what I understand I don't think there's "no reason" to run the E2X. I discussed this with my builder and he mentioned something along the lines of the E2X providing constant suction to the crankcase which helps alleviate pressure. Might not alleviate pressure AS effectively as venting to atmosphere, but is a safer bet for a road-course car, and for the 700 WHP ish level I'm chasing it would be plenty. E2X has also been proven to quantifiably capture more gunk from the PCV system.
Regardless, I acknowledge the merits of the MM design (and if I knew they made more road-course tailored options I would have considered it more heavily). I think it's disingenuous to say there's no reason to pick the E2X though.
The conclusion I drew from trying to pick myself is how terrible both MM's and EE's websites are, and how confusing this is to the lay person like myself. I got so frustrated that I just asked my builder his opinion, and he has had better experiences with the EE can, so that's what I picked.
SammYyYyY is offline   Reply With Quote
Old 05-20-2025, 04:57 PM   #25
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
In my opinion, the Elite/Tracy Lewis patented design was much better than the original MM designs for capturing oil. You can see this in the independent testing that is on the internet. I think the newer 2 MM revisions (gen 5 and 6, and maybe gen 4) have significantly or completely closed the gap on the design as far as capturing PCV oil goes. I think both website are confusing, but the MM website is slightly better on choosing what you need and getting a complete package. I had to piece my E2X Ultra setup together based on their website and what I needed. It was confusing at best.
There is data out there that shows the E2X 2nd-port venturi barb actually generates a small amount of vacuum while under boost. I really liked the design of the can and setup. They note it to be rated for 1000 at the crank.
With my new build phase, I am going with a MM Wild for the 1200hp -12AN setup. I saw there is also a new version of the Motion can that has a check valve, much like the MM can. I think that is another player worth considering as a high-hp alternative.
Mods being installed-
Old 05-20-2025, 06:14 PM   #26
AZIROC
OEM
