Old 05-14-2025, 08:43 PM   #15
Delran
Drives: 2023 2SS 1LE Riverside Blue 6M
I have never meet a clamp I liked from any header brand. On my ZL1 I finally did it right and had everything welded up with V-bands, and BOY does that make things easier for future work, not to mention the elimination of any and all leaks. My only suggestion is to have the system welded up prior to sending it out for the jet-hot coating.
Did you just do V-bands from the Headers to the cats, or the entire catback system? I assume if you wanted to do everything you would need to put everything on to check fitment.
Delran is offline   Reply With Quote
Old 05-14-2025, 08:48 PM   #16
Originally Posted by nissandr View Post
Wtf this post supposed to mean?
We met and he checked the smell of my exhaust, that is, the lack thereof.
Old 05-14-2025, 10:15 PM   #17
vince3
Drives: 2022 Vivid Orange LT1-M6
Did you buy the CSP header -
https://www.cspracing.com/complete-s...RoCGvUQAvD_BwE
or CSP headers that are supposed to be the same as Kooks but manufactured by CSP?
https://www.cspracing.com/kooks-2260...xoCKkwQAvD_BwE
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 05-15-2025, 05:44 AM   #18
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
LOL what?!
As if there needed anymore confusion here.
I saw a CSP install vid on YouTube. The headers said CSP on them, but they had one of those stupid swivel clamps and I thought maybe CSP changed over to that style clamp.
But you’re telling me CSP puts their label on Kooks headers?
Ok, so do you know if CSP still makes the headers which have the older design connection where the bolts pull the connection together?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 05-15-2025, 06:59 AM   #19
SWFLZL1
Drives: 2022 ZL1
Originally Posted by Dynamical View Post
LOL what?!
CSP designed their own headers, but have never manufactured them. Originally, they were made by SW. Now they are made by Kooks. The ones made by Kooks do not have the bolted connection, but use the same connection style as Kooks does. Unless you find a used pair, all new CSP headers will have the new design header connection.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 05-15-2025, 08:56 AM   #20
Dynamical
Dynamical's Avatar
I just talked to CSP and I can confirm you are correct, the CSP headers that are now made use the swivel style clamp and are no longer made with the 2 bolt flange. Kind of a disappointment for me as I was considering the CSP for the 2 bolt flange vs swivel clamp.
Thanks
Old 05-15-2025, 09:06 AM   #21
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
I bought some catless connection pipes that are for the newer style clamp. Ended up using these to connect: https://www.amazon.com/Rwraps-Split-...0_17_cp_i&th=1
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
