#15 | |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
#16 | |
![]() Drives: 2023 2SS 1LE Join Date: Dec 2018
You live in a warm climate? Mine has started the heated seats every morning automatically since I bought it; except in the hot summer days when it kicks on cooling. I’m usually disappointed when neither kick on automatically lol. Sent from my iPhone using Tapatalk |
#17 | |
#18 | |
When you remote start the car, if it's cold, seat heaters and cabin heater come on; if it's hot, seat coolers and A/C come on automatically. The manual even says the seat heater/cooler LEDs won't light up with this automatic activation, but they will be on when needed. Once you press the start button, they all turn off until you push the appropriate buttons. There is a wide temp range in the middle where neither heating nor cooling is activated automatically, so this can really only be tested in the winter or summer.
#19 | |
#20 |
I had my update performed at the end of March. I didn't drive the car a lot until recently. I have noticed that I need to pull the inside driver's door handle twice to get the door to open. The passenger door always worked this way, but the driver side always opened on the first pull. Additionally, I must push the door lock button on the driver's outside door handle twice for the doors to lock. It used to lock on the first push. These behaviors changed after the BCM update. Anyone else experience this?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
#21 |
I haven't experienced any of those issues, neither before nor after the update. Only one push or pull to open/unlock for me.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#22 | |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
If so, my car has always been that way, before and after update. The button on the handle should just toggle to the opposite of what the lock state already is. So, if it's unlocked, one push should lock it. If it's locked, one push unlocks it. |
#23 |
Yes I mean exactly what you said but before the update I only had to pull on the inside driver’s door handle once to unlock and open. Passenger side was always two pulls.
To lock from outside I have to push the outside button twice. Before the update it was only one push to lock. Sent from my iPhone using Tapatalk
#24 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#25 | |
I’ve looked but didn’t see anything. I’ll look again. Sent from my iPhone using Tapatalk
#26 |
Thinking about it, I think the car is supposed to unlock the doors once put into park with e brake on.. I only have to do the "two pull open" if I do something like leaving the car running while getting out for a second, or I didn't put on my e brake/shut the car off before opening the door.. I'll have to do some testing to be sure of this though
#27 |
![]() Drives: 2020 2SS 1LE Satin Steel Metallic Join Date: May 2020
Shortly after I had the update the engine light came on and my code reader indicated 732-734 codes which are for auto trans cars and I have a manual 6. Then I got the parking assist icon with wrench causing the gear indicator or back up camera to not work. Dealer said low voltage on battery caused a loss of communication and they cleared the codes. 9 miles later engine light came back on along with the paring assist icon etc. just like before. I told them I didn’t have any problems until after the recall was done they claim that couldn’t do it. I checked on here and sounds like others had issues but not quite like mine.
