Old 05-09-2025, 04:56 AM   #15
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Under the rear drivers side wheel well cover, there is a harness that needs to be moved otherwise the wheel can potentially rub and cut into the wire.
There are several forum threads on this and how to move it.
Spaceme1117 is offline   Reply With Quote
Old 05-09-2025, 09:03 AM   #16
LateBrakeU2
Drives: 15 RH Z/28, 23LT1VOM
My LT1 on 1LE takes offs (305/285) with H&R sport springs, no rub.
https://imgur.com/a/ZH31Xga
LateBrakeU2 is offline   Reply With Quote
Old 05-09-2025, 02:56 PM   #17
BatMobileLT1
BatMobileLT1's Avatar
Drives: 2023 Camaro LT1 M6
Your idea will work. 265s on 10" wheels will look a bit stretched, but not too much. I absolutely love SS 1LE wheels, they look perfect and are very sturdy.
Note that some tires are wider than others even at the same nominal width. For example, the Michelin PS4S is on the narrower side compared to, say, Goodyears. Check the exact tread width spec on the tires you're planning to purchase.
Thanks for the confirmation!
Yes - next step is to look at/compare the specific tire options, if I can do the 305/30 rear tires I was leaning to go with Conti EC Sport02.
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers
BatMobileLT1 is offline   Reply With Quote
Old 05-09-2025, 06:02 PM   #18
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
You can do 265/35/20 up front and 305/30/20 rear. They will be the same diameter (well...within 0.1"). You would NOT want to go taller in the front, or else you risk pissing the ABS gods, and they will smite thee with ice mode.
If I were you, though, I would just do 285/30/20 up front with 305/30/20 rear. No good reason to avoid the factory SS 1LE (and ZL1) fitment. The ABS will be fine with a slightly shorter front tire. You'll have about 0.5" shorter tire in back than your stock skinnies, but that's a difference of slightly less than 1mph on your speedo. That's just not a problem...and it might even help you avoid a ticket someday.
Even though 305/30/20 is stock SS 1LE fitment, I would still do the harness relocation in the driver's side rear well, as mentioned. They have rubbed through on stock Camaros before, and this is something you'd muuuch rather prevent than repair. It's so easy there's no good reason not to.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
245/40, 305/30/20, lt1, rims, tires
