Old 02-12-2025, 02:02 PM   #15
Vettethret
Vettethret's Avatar
Drives: 2023 ZL1 1LE
Originally Posted by SWFLZL1 View Post
Nice, I’ve talked to Joe before, seems like a great guy. I was originally going to go the 2650 route right out the gate, but decided to go with headers, Roto fab, and e to start. I also have the csp headers and high flow cats (which I think are the gesi’s) and I can tell you traction is a no go in 1st or 2nd. (I have a m6)
Curious about the harrop, he did t offer that as an option when I talked to him. Is it the same price as the Maggie, or is there other benefits over the Maggie? Haven’t heard much about them on a lt4 yet.
Joe liked the 2650, Erik liked the Harrop which is what I was going to do. Im not sure if there are any benefits going one or the other, I was open to either. I am curios to hear from anyone with the Harrop.
2023 BMW X4M Competition (Downpipes, Midpipes, Intake, Exhaust, Tune)
2023 ZL1 1LE BC Forged KXO5, 325/345 R888R, KPMF Satin Pearl Wrap, 2650/Heads/Cam/3200 stall/Meth- 918 rhwp/842 rwtq, Girodisc/Carbotech AX6, Race louvers.
Vettethret is offline   Reply With Quote
Old 02-12-2025, 02:22 PM   #16
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Not that I know much other than the LT4 Chevy blowers. But, Maggie seems to be popular and in wide use on a lot of the ZL1 LT4 builds! So, maybe it's a decision to be made based on popularity knowing that most that have a 2650 has had zero issues? I personally love the whine of my Kong X-Port'ed LT4 blower. I have a friend that has a Stage 5 package build with a NW112mm and a 2650 etc... on his ZL1 1LE and he dies for the sound that my blower makes! He's also shocked that I hang with him on the 60 to 130 rolls we do. I may have even inched by him a few times!!!. I paid about 1/2 the cost for my build to date as he did for his build!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 02-13-2025, 09:17 PM   #17
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Since I used the secondary cats as my only cats after my LTHers (I want the stock Cat look for the inspectors here in Thailand), you all are making me want to pull them and see what they look like inside. Since I welded in flanges, it won't take long. But it sure would be interesting to know. I monitor the temps of them with the i-Dash. It's still a slight bitch to tighten them in correctly because of the 3 holed flanges. But when I get back from the states in April, I'm gonna do it and inspect and clean them. I guess it will also give me a chance to port the flanges if there's a slight misalignment.
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
Bangkok_ZL1 is offline   Reply With Quote
Old 02-25-2025, 07:32 PM   #18
Miamidchi
Drives: Chevy Camaro ZL1
Maggies can whine like crazy if you spin them faster. Also, very much recommend the Too High PSI lid for it!!! They run slower than the stock blower. The big reason i went maggie was the cooling is probably the best out there, and they are still rwtq monsters like the factory blower. I have the 4.5" cats on my car, I'll be interested to see if they last also as i am jumping up to somewhere in the 1200rwhp+ range.
Miamidchi is offline   Reply With Quote
Old 02-25-2025, 07:47 PM   #19
2023_ZL1-AUTO
Drives: 2023 ZL1
Originally Posted by Miamidchi View Post
Maggies can whine like crazy if you spin them faster....
They do for sure! But, you wanna hear some serious whine!!! X-Port a stock 1740 LT4 blower, add a 9.45" lower and a 2.3" upper! The whine will literally be the only thing you can when at WOT !!!!
Old 02-26-2025, 05:34 AM   #20
clg82
Drives: 2020 Camaro ZL1
That's because it's screaming from the heat
