Old 05-21-2025, 05:03 PM   #15
DeuceCam
Drives: LT1
Originally Posted by keep_hope_alive View Post
investing in lift pads and four jack stands makes stuff like this really easy. Especially since we have a lift point between the two jack stands, you can get the entire car in the air in two steps. Having a pinch weld lifting puck also helps protect the lower skirt when using the lift point.
What lift point between jack stands are you referring to? Afaik, this car is a pita to get on 4 stands because it doesn't have a safe front, center lift point
DeuceCam is offline   Reply With Quote
Old 05-21-2025, 08:03 PM   #16
GreyGhost702
Drives: 2019 Camaro 1SS1LE
Personally, the only "safe" way to support the car in a full lift situation is to have it on a car lift, post or roll on. 4 Jack stands, there is no such thing as "safe" there is always potential risk for the car to shift. I've had a buddy get stuck under a car after a jack stand failed. It's still in my top 5 "Holy Shit" moments. He is lucky to be alive. I'm not saying you're not aware, I'm just reiterating we can only make it as safe as we can on 4 stands. A lift would be the most safe, but also the most expensive/inconvenient.
The front center pinch weld is the safe lift point. The jack point is the one people have a hard time with. I personally don't like using the front-most pinch weld as a jack stand support point. It's too damn close to the front center jack point. I also don't like the jack stand head (on most stands) is U shaped and you're supposed to set that jack pad on it. Car has too much movement during lifting/lowering for me to trust the pinch weld pad to stay on the jack stand head. One slip front or back and the stand will be in the floor or through the door. I place my stands on the center-most frame rail, pretty much where my long tubes connect. It's not my favorite place on a car, but the rail is beefy enough to take the weight and give the stand enough contact area the car shouldn't shift or slip unless you're really rocking the car something fierce. As for the rear, the rear comes up when you jack from the front-center pinch weld jack points. I place stands under those pinch welds, also using pinch weld pads. And there it is, the car is on 4 points and airborne.
I also use poly style jack stand sleeves. I don't like metal-on-metal particularly when it comes to setting the pinch weld pads into the jack stand head grooves. It doesn't give me good vibes. The friction isn't there to keep the car or stand in place should lateral force be applied and the risk will be higher for it to slip off the pad.
Overall, the 6 Gen Camaro is a shit design when it comes to jack stand placement and jacking points. Compared to other platforms I've owned through the years. The Camaro takes the crown and I hate it for it. Right out of the gate, you need special equipment just to lift your vehicle (pinch weld pads). Another gripe, they specifically tell you under no circumstance to jack from the diff. As a prior Mustang owner, this is exceptional weaksauce. Jacking from the diff was a go-to, even in the Terminators with an IRS. Having crawled all over under my car now, I haven't seen anything that warrants this warning to not jack from the diff, other than implying that the diff housing itself isn't durable enough to act as a lift point for the rear half. Again, from the look of it up close, I don't see why not. But I digress. The rear lifts just fine from the front-center pinch welds, fortunately.
I did myself a favor (depending how you look at it) and bought a 2nd low profile jack during a harbor freight sale. It has made it way easier to jack the car up since I can keep a jack under each lift point in the front. Doing it one side at a time just never felt very controlled. Much better with 2 jacks. And if you have a buddy with you, all the better.
I have to put the car up on all 4 again this weekend, so I'll take a few shots of my stand placement for ridicule, lol. Somebody won't like it, but I pulled the engine and transmission and put it back all by my lonesome with the car posted up on all 4 for months and never had the car or stands make a peep.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 05-21-2025, 08:50 PM   #17
IMO the jacking situation, while not ideal, isn't that bad.
The chassis designers thought of this, the car has 6 lift points and the chassis is so stiff that lifting from the center point raises that side completely, so two jack stands can easily be inserted on one side, and then one can move on to the other.
I never had a problem using a single jack, although having two plus a buddy to operate the second one is even better.
Also, I bought hockey puck style pads for the jack and 3-ton rubber adapters for the jack stands, so there is never any metal on metal connection and the car is rock solid at every stage.
Old 05-22-2025, 08:22 AM   #18
p47dman
Drives: 2024 Camaro 1SS
p47dman is offline   Reply With Quote
Old 05-24-2025, 11:21 AM   #19
DeuceCam
Drives: LT1
Interesting. Are you lifting 1 whole side and placing stands on the front and rear pinch weld locations on that side, then lifting the other side of the car and placing stands on that side? Sounds sketchy.
Old 05-24-2025, 03:01 PM   #20
With proper jack stand placement, why would this be sketchy?
Old 05-24-2025, 07:02 PM   #21
DeuceCam
Drives: LT1
I've never lifted a car onto 4 stands that way, so it seems weird to me; moreover, using accessories with this method, e.g., zl1addons lift pads, the rubber covers you linked, etc., makes me even more anxious. In my head I picture the car slipping on the stands or jack, or the rubber piece failing. That said, I haven't tried this method, and I'm not an expert on the subject, so please take my remarks with a grain of salt.
I've always used a front, center lift point (between the front wheels) when working on all of my past cars as well as my dd (lift the front, place the front on 2 stands, then lift the rear, place the rear on 2 stands). However, I don't believe this method is an option with the Camaro; i.e., the front center lift point (between both front wheels).
Apologies if I took this tread off track.
Old 05-24-2025, 07:42 PM   #22
Last reply to allow others to steer the thread back to diff fluids, but the Camaro chassis is so stiff that the entire side will lift no matter where you put the jack, you can't jack only a single corner anyway. When you're done with one side and jack up the other, and you only have one jack stand in, the car will drop back onto one wheel plus that jack stand, not sure if it's much safer.
I have done it both ways, using 4 jack stands when I want the car to be level and 2 when not, never had any issues. That said, I welcome any new information or anyone pointing out flaws in my method.
