#15 |
![]() Drives: 2023 2SS 1LE Join Date: Dec 2022
Go with ARH, do it right the first time. You get what you pay for. Don't think of them as "expensive", think of the others as "cheap for a reason". Speed Engineering is a Chinese shell company, if "buying American" matters to you. I'd also be happy with Kooks or CSP.
#16 |
![]() Drives: 2017 Camaro SS Join Date: Feb 2023
I want to say 200. I had mbrp axle back b3fore this and it was pretty loud. But now with dual 3 inch I had to put some real mufflers on it. Still loud but a different loud, deeper for sure. I bought the cheapest stainless quad tip cat back on ebay and used the mufflers out of the system. For the money It looks and sounds really good
#17 |
I have the Speed Engineering 2 inch headers and have had zero issues with them. Got their plug wires with the headers and all is good there as well.
2016 Camaro 2SS A8 || SE 2 inch Longtube Headers | SE Offroad X-Pipe | Corsa Extremes | DSX Flex Fuel Kit | MSD Atomic AirForce Intake Manifold | NW 103mm Throttle Body | Roto-Fab Cold Air Intake | Oil Catch Can | e85 Dyno Tune
#18 |
![]() Drives: 22 LT1 Join Date: Apr 2022
Ive read that kooks makes csp’s headers for them. I did see a few weeks back they had a really good sale on the with connection pipe
#19 |
![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
Yep should have bought. Sold out for weeks now
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph |
#20 |
![]() Drives: Camaro SS Join Date: Sep 2022
I'm running Texas speed 1 7/8 with high flow cats. No fitment issues, no emissions issues.
#21 | |
I will say that 1) installation is best done by someone with experience (unlike yours truly), and 2) the passenger side header does route close to the starter, but there is still enough of an air gap, I've never had an issue warm or hot starting the car.
#22 |
New question. I think I read somewhere that pray said that TSP headers make a little more power. Anyone have any feedback on power differences? From what I’ve read, size can matter but also the length of the primaries can make a difference. Long primaries = move power band up (tsp seems to be the longest) and shorter primaries (maybe CSP or Kooks) delay the power band.
#23 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
I am running the ARH 2.0" primaries and they fit perfectly. No need to remove the steering shaft or the starter, went right in. I did move the right side brake line and wrapped it with heat shield. So far the car is quiet, makes 780whp and 807 lb/ft of torque with the stock cam and SC... so I must be doing something right!
#24 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
GM Gen V Calibrator
#25 |
all long tube headers gain the same on a basic bolt-on LT1 as Jason mentioned. It has been dyno tested. ARH nor Kooks make more power than Speed Engineering. If you want a quality header at a more reasonable price, look up the new LTH headers. Said to be ARH quality for around 1200.00.
https://longtubeheaders.com/products...l-titan-finish
#26 | |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
#27 | |
You will want the GESI cats if making a good amount of power. For NA I would think the standard High flow would be fine.
#28 | |
With discount code I can get these kooks for $1359 shipped. https://www.cspracing.com/kooks-2260...-2260h610-csp/
