Old 11-10-2024, 02:02 PM   #15
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Well, that was an important detail...
Who tf does digs on street tires.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 02-13-2025, 04:43 PM   #16
DriftR
DriftR's Avatar
Drives: 2024 LT1 Camaro
Originally Posted by sactownbwoy View Post
I have aftermarket wheels on my ZLE, Advan GT Beyond. Rears are 20x11 +35 and I run a 325/30 20 on them. Been doing it for over two years without issue.
Great wheel choice, car looks sick! What tires are you running? Not finding much in 325/30R20
DriftR is offline   Reply With Quote
Old 02-13-2025, 05:05 PM   #17
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I believe I have read going to 325 on the rear you have to relocate a wiring harness or it will rub.
dpevans is offline   Reply With Quote
Old 02-14-2025, 10:00 AM   #18
DriftR
DriftR's Avatar
I believe that is only if you have magnetic ride control, which I do not.
Old 02-14-2025, 10:34 AM   #19
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
While we're on this topic...
I'm running OEM 1LE wheels with SC3 on my 2020 2SS. I noticed that at the front of the front wheel wells, the tires stick out more than I remember them sticking out when I had a 2017 1SS 1LE. Are the front suspensions different width-wise from a 1LE to a standard SS? My car does have the lowering option from when it was ordered so I wonder if that made any difference. It's also possible that I'm not remembering my 1LE. Any info is appreciated.
Bad Anvil Garage is offline   Reply With Quote
Old 02-14-2025, 10:46 AM   #20
DeuceCam
Drives: LT1
It could be a difference in the alignment on both cars. Also, considering those years have different front bumpers, I'm not sure of the bumper line is identical at that point.
DeuceCam is offline   Reply With Quote
Old 02-14-2025, 01:35 PM   #21
jzenobio
jzenobio's Avatar
Drives: 2018 Camaro 2SS
Going to a 305/35/20 would do a lot more for your spinning than going 325/30/20 will FYI. Or get a softer compound tire. I run 315/30/20 R888R out back on the street and as long as it’s warm (and not at full boost lol) the traction is pretty good.
Are there any mods or spacers needed to run the 1Le 305's or going up to 315?
2018 Camaro 2SS
2024 A5 Sportback
Former:
2017 Genesis G90 5.0
2017 Jaguar F Pace 3.0 Supercharged
2016 BMW 535i xDrive
2015 Chrysler 200S
2012 Jeep Wrangler 2 door
2009 Mercedes C350
2007 Toyota Rav4 Sport V6
2006 Pontiac Grand Prix GXP
jzenobio is offline   Reply With Quote
Old 02-14-2025, 02:49 PM   #22
DriftR
DriftR's Avatar
I noticed the same when I put 1LE wheels on my '24 LT1. I actually added 6mm spacers in the rear so the slight amount of poke matches front and rear.
Old 02-14-2025, 02:51 PM   #23
DriftR
DriftR's Avatar
No.
Old 02-14-2025, 07:20 PM   #24
Originally Posted by DriftR View Post
No.
Stating the obvious for posterity, you do want wider wheels, though.
Trying to fit the 305 or 315 wide steamrollers over the stock 9.5" rear wheels is not recommended. A couple mm here or there is fine, but this would be a major difference.
Old 02-18-2025, 05:46 PM   #25
DriftR
DriftR's Avatar
Stock 1LE rear wheels are 11”… 315 is fine for the rears, not square set up.
Old 02-18-2025, 07:06 PM   #26
True. However, the guy who posted the question I responded to has the signature below (that doesn't say 1LE), and he may well have meant just the tires, given the cost of true 1LE wheels.
Even if he has 1LE sized wheels, though, there will also be plenty of people who read posts in isolation, so I thought this table of desired wheel/tire width pairings would be helpful.
Old 02-19-2025, 02:37 PM   #27
Bad Anvil Garage
I considered this. So I'm not crazy... you've had the same issue. Now I'm really curious about the suspension differences between a 1LE and SS. The hubs must sit in different places.... but why exactly?
Old 02-19-2025, 03:13 PM   #28
DeuceCam
Drives: LT1
^I misread your prior post. (I thought you were comparing the front tire poke on different model-year 1LE models.)
I also noticed more front poke on my LT1 with (near) 1LE-spec wheels (I have 19x10 +20mm front and 19x11 +40mm rear) - that was with stock suspension, ride height and alignment. Now I'm lowered around 1.25" on KW coilovers with -2* camber front and rear, and the front poke is more in-line with the rear poke.
