Old 10-11-2024, 07:58 AM   #15
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I've had my driveshaft out, literally, 5-times and can't fathom how it could be rubbing... Regardless - are you sure it's not a wore-out carrier bearing or something? Or tranny mount? It can't be cradle shift or something, being a ZLE. Are they sure it's not the heatshield rubbing on it? There's a single bolt-on floor brace, that's right behind the tranny mount area, where it's close to the DS, but your couplers would have to be hanging on by threads for that to be an issue. Something doesn't sound right...
Considering what happened to Andrew at CSP, and whatever driveshaft he was running (I forget...), I'd stay away from that CF one. That one let go in spectacular fashion.
At your power, it seems like everyone says that tranny needs upgrading.
'20 ZL1 Black "Fury"
Old 10-11-2024, 09:37 AM   #16
JSH
JSH's Avatar
Drives: '20 ZLE
No lol… I’m on a GForce aluminum one piece. The OEM SS driveshaft is weaker than the ZL1 DS so I snapped it a while ago.
If you’re on the OEM DS I’m just wondering how it could be rubbing in the tunnel, unless the rubber mounts are cooked.
I'll take some pics Monday.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 10-11-2024, 10:10 AM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
He installed my new engine in February, so whatever condition is there is one that he's seen. The DS has never been an issue previously.
2020 ZL1LE A10.
Old 10-11-2024, 11:57 AM   #18
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I wouldn’t run anything DSS makes. QA1 CF shaft has been very solid based on what I’ve seen.
Old 10-11-2024, 12:03 PM   #19
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
I'm still on stock driveshaft but I have bent driveshaft bolts. The only way I could see it rubbing is if the carrier was really worn out letting the driveshaft move around alot. That or trans/rear cradle mounts are all out of wack letting the driveshaft get near the tunnel. I'm also wondering if its rubbing on a heat shield and not the actual tunnel but with you having a vibration, I'm guessing its that carrier in the middle thats a problem.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 10-14-2024, 03:18 PM   #20
JSH
JSH's Avatar
Drives: '20 ZLE
He showed me where the drive shaft was rubbing on the exhaust. I'll take it out probably tomorrow morning and it won't take but just a few minutes to find out if it's if that's what it was
2020 ZL1LE A10.
Old 10-15-2024, 07:49 AM   #21
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
So, do I send it to Pure or not?
For how you use the car and your power level, yes. Better to get ahead of issues versus having them start at a track rental or event and wasting the outing.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 10-15-2024, 09:36 AM   #22
JSH
JSH's Avatar
Drives: '20 ZLE
When I got to the shop yesterday, the car was on the lift. The rear main seal leak looked worse than I expected, and the bottom of the trans was covered with oil. Then we moved down and inspected the driveshaft and axles. I looked at him and said, "Considering the oil leak and inevitable clutch death, this would be a great time to replace all three." He surprised me by saying, "I wouldn't."
I told him Pure said to put it on a pallet and send them the address. He said, "Let's wait until it's closer to death." How many shops would turndown that project?
Oh, the noise is predictably worse since we did the rear seat delete, so we're going to do a underbody sound insulation tape.
2020 ZL1LE A10.
Old 10-15-2024, 09:38 AM   #23
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
I told him Pure said to put it on a crate and send them the address. He said, "Let's wait until it's closer to death."
Interesting response. I would see that as a reason to just get it done.
GM Gen V Calibrator
Old 10-15-2024, 10:42 AM   #24
ZL1Atlanta
ZL1Atlanta's Avatar
I told him Pure said to put it on a crate and send them the address. He said, "Let's wait until it's closer to death." How many shops would turndown that project?
Maybe he thinks he’s looking out for you by helping you save money today, which really just means kicking it down the road until later because if you’re going to keep racing the car, it will need a trans rebuild. Once I got to the point of carrying a spare trans, we would preemptively replace it just so I had higher confidence that I wasn’t wasting an outing should it start having issues. It also gave Pure a chance to see how it was aging with abuse.
Old 10-15-2024, 07:03 PM   #25
JSH
JSH's Avatar
Drives: '20 ZLE
OK, the problem [vibration and noise] remains the same. I'm not a 10L90 expert, but I don't believe slipping clutches would feel and sound like this issue. It's very much like driving on the rumble strip. That it starts when the meth hits is the only clue, so I'm going to turn the Gain down a tad.
2020 ZL1LE A10.
Old 10-16-2024, 08:00 AM   #26
ZL1Atlanta
ZL1Atlanta's Avatar
Check your VSS data when that happens and see if it is smooth as you’d expect. On a couple of occasions when I had a trans going out there would be a vibration and in the logs I’d have smooth engine acceleration but speed was rugged looking with some unusual peaks and valleys. At the same time, trans and TCC slip weren’t that bad.
Also, check the bolts on output shaft/rear cover to make sure they aren’t loose. I have had that happen also. Pure created a fix for that some time ago.
Old 10-16-2024, 11:03 AM   #27
JSH
JSH's Avatar
Drives: '20 ZLE
He said it was rubbing an exhaust pipe. But that's not the problem I hear.
2020 ZL1LE A10.
Old 10-16-2024, 06:35 PM   #28
JSH
JSH's Avatar
Drives: '20 ZLE
We're going back to the last pre-meth tune and turn off meth to see if it does the same thing.
2020 ZL1LE A10.
