Old 09-19-2024, 06:48 AM   #15
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
The A052 is a first-lap tire on track. After that, it will overheat and the grip will fall off. As an autocross tire, they are one of the two fastest 200tw tires available right now; the other being the Bridgestone. But even there, you have to spray the Yok between runs unless it's a cool or rainy day. At least based on the Tyre Review test, the new Hoohoo appears to stay fast over multiple laps, so it's less heat sensitive than the Yok.
The big question is whether or not the new Hoosier will be legal for SCCA street tire classes. Those have have had their hands on them so far are saying their molded tread depth is only 5/32", whereas the rules require 7/32. So it doesn't look like this tire will be legal...but we shall see. The Yok wasn't legal for the same reason when it first came out, and then it suddenly found the magic tread depth required after a year or two.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 09-19-2024, 10:12 AM   #16
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I've been using CRS V2 305/30-19 the past year for various TT events that require 200TW and really like them. I'd love to get some of them in 315/30-18 if they ever become available again. Latest TR estimate is early November.
Like Msquared said, we'll have to see what SCCA and other groups think about the new hohos.
Andy is working on a comparison review with new hohos and other Super 200s and will have news on grassrootsmotorsports.com soon
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 09-19-2024, 10:35 AM   #17
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
It's interesting there's tread depth rules and then people shave tires anyways, and the whole 200tw thing is total BS anyways. If my PS4S are 300, my REs are about 75 . Many SCCA rules don't make a lot of sense to me though I guess they make sense to some.
Old 09-19-2024, 11:33 AM   #18
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Interesting! Looks to be a pretty good HPDE tire. I wonder how it compares to Nitto NT01s?
ariZona28 is offline   Reply With Quote
Old 09-19-2024, 12:01 PM   #19
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Yeah, I can't speak to autocross but I've been pretty underwhelmed by yolks for time attack. They aren't even fast on the first lap vs the nankangs. Both are best on lap 1 though, depending on track length I can get 2 fast laps in.
Christian1LE is offline   Reply With Quote
Old 09-19-2024, 02:26 PM   #20
BoilerUP
BoilerUP's Avatar
Drives: Cadillac ATS-V
TrackDayTire sells the TrackAttack Pro, and their sponsorship codes work for them. With a sponsorship code, they're cheaper than CRSv2 (which are still unobtainium in most sizes).
Andy Hollis of Grassroots Motorsports seems pretty set that the TAP is faster than all current Super200s, and likely faster than the TrofeoR and SC3R. Guess we'll see when reviews start rolling in over the next few weeks/months.
SCCA may want 7/32nds tread, but I don't think GridLife or Global Time Attack has those restrictions.
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber*Pitt Race*VIR
BoilerUP is offline   Reply With Quote
Old 09-19-2024, 10:43 PM   #21
Msquared
Msquared's Avatar
I think the main reason for the 7/32" requirement is to dissuade tire companies from making a rubber compound that's too soft and unstable to work at that tread depth. IOW, it's not really about the tread depth per se, but about keeping the compounds semi-streetable. That said, the two current 200tw autocross kings - the A052 and RE71RS - are already over the limit IMO. Neither lasts very long in competitive condition: the Stones heat-cycle out after 70-80 runs and the Yoks just cord quicker than that. And the Stones pick up OPR at Lincoln like crazy, meaning you have to scrape or swap tires between runs for best results. And the Yoks overheat if you breathe on them. All of that means neither of these are truly street tires, although they are streetable to an extent. The last true street tire was the Falken RT660.
The 200tw rule by itself isn't enough. I'm more convinced than ever that the only real solution for street tire classes is a spec tire model, but getting a company to make all the required sizes for all the classes is probably impossible.
Matt Miller
2020 SS 1LE
Old 09-20-2024, 04:20 PM   #22
BoilerUP
BoilerUP's Avatar
I've found the RE71RS is surprisingly good on the street, both around town and on the interstate. Made a half-dozen trips to/from NCM on them (1+40 drive each way) and they're surprisingly comfortable with mild for category road noise.
Can't speak to autocross applications, but for HPDE I've found wear to be the LIMFAC for the 71RS..20-25 sessions max on a heavy Alpha chassis car with greater than factory camber.
Old 09-20-2024, 10:33 PM   #23
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Waiting for an SC3R comparison. The SC3Rs are amazingly good, work across a wide heat range, wear well, are consistently sticky when driven well, handle progressively at the limit. A lot cheaper too on Discount Tire. If the Track Attack Pro have those attributes and wear longer, I am in.
wakespeak is offline   Reply With Quote
Old 09-21-2024, 03:31 PM   #24
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
I have way over 80 runs on my RE-71rs's and they aren't heat cycled out. They are still fast as hell. I have a few events where I had a co-driver and we had 8 laps each. If my math is right these have 100 runs on them, and still look really good. My eyeball says 3-4/32nds left on them. My car is pretty hard on tires too.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 09-21-2024, 04:31 PM   #25
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Same here. 108 autocross laps on my RE71rs 285/35/19s. Still fast as heck and rocks still stick to them! Still has half the tread before the wear bars are hit. A friend that runs them in his caddy in 295/18s says same, gets 120 runs and track use as well. And says as I feel, seem to get faster the more they get used and get to be more like slicks, to a point of course where heat cycles will take hold. We will see. My old Nankang v1s were dead before 150 runs to the point using track race was faster as it kept me from over driving like Nannie’s were off..lol
On a side note these tires on 10.75” wheels gained a 1/2 second on friends R 660s, and are as fast as my old nankangs305/30/19s. Another comparison with a zl1 with 12 run RE71 305/30/19s vs my 96 run tires gained him no ground . I race him all the time and he does 2x the events and tires as I do
VR Baron is offline   Reply With Quote
Old 09-22-2024, 09:25 AM   #26
carguy55
carguy55's Avatar
Trackdaytire confirmed 5/32 tread depth on the new hohos
Old 09-23-2024, 11:12 AM   #27
bptuner
Drives: 2018 zl1
One good thing is you'll get a very current date code when you order the new Hoosiers. I couldn't get a date code newer than 2022 last year in the SC3R's.
bptuner is offline   Reply With Quote
Old 09-23-2024, 12:57 PM   #28
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Brand new tires are usually significantly slower than tires a few heat cycles in.
Unless you’re talking about the mold release stuff on very fresh brand new tires I have seen Randy Pobst say the exact opposite of this a few times. According to him tires are at their grippiest when new and on their first ever lap post a warm up lap.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
