Old 09-12-2024, 10:32 AM   #15
Z OH 6
Drives: 2024 CT5-V Blackwing
Yea I agree which is why I run the Metco breathers on my engines. But the MM wild does work well if you increase the breather line(s) diameter to -10 as I mentioned prior.
That is one nice thing about Whipple's. Is they upgrade the factory vent lines with their kits. It definitely becomes an important thing to address as you turn the boost up and make more power.
And I still believe catch cans are important to keep oil from being ingested. That will cause detonation and power loss. Stock LT4's get quite a bit of oil blow by through the PCV system. I have seen oil pooling inside the supercharger lid.
I agree here and if JSH didn't upgrade the breather line as his power and boost level increased this was bound to happen eventually.
Old 09-12-2024, 12:08 PM   #16
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I avoid the catch can and just use a gently spray of water/meth to keep the whole upper engine clean
Old 09-12-2024, 12:23 PM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by jlaudio11 View Post
I understand you have the race can but what size lines and where are you running them from? We're similar power levels and I have actually too loose of ring gap so I get some blow by, but I'm just going to a generic catch can with 5/8 lines off the stock valve covers. I did put an ls3 front seal in when I had my engine apart. I think I actually reused my stock rear main seal. Cant remember right now.
The -10an lines come off the back of the valve covers. MM has suggested a few things including -12an lines
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 09-12-2024, 12:32 PM   #18
JSH
JSH's Avatar
Drives: '20 ZLE
I run metco breathers on my engines. That being said the MM wild catch can has a breather so it should do the same thing, but you might try adding the Metco breather on the Valve cover.
I had a rear main go out on a new 5.3 LS(mild build) that was less than 1k miles old. Replaced seal added Metco breather, no issues since.
If you don't want to try the Metco breather, One thing you will want to make sure is that your breather lines are all upgraded to -10 and routed correctly for the MM wild can to vent crank case pressure efficiently.
MM says:
you can hook the valley plate adapter or spare valve cover port(s) to one or both of the outer ports on the stock black box, since it appears the exit of it is still connected to the cold air intake
you can also unhook the lines at the valve cover and blow toward the can
this should be very easy to blow, and may find a restriction somewhere perhaps also double check the fittings in the valve covers for not necking down on the hose size
if the valve cover fittings are -10 port, we can go up to full flow -12 with our parts
2020 ZL1LE A10.
Old 09-12-2024, 01:12 PM   #19
JSH
JSH's Avatar
Drives: '20 ZLE
What if I start by putting a nipple in the oil fill opening and attaching a breather cap to it and see if the leak responds
2020 ZL1LE A10.
Old 09-12-2024, 01:32 PM   #20
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I wouldn't do that because then it's just open to atmosphere. The metco breathers have a check valve disk that closes under vacuum.
Old 09-12-2024, 04:16 PM   #21
JSH
JSH's Avatar
Drives: '20 ZLE
I now see both valve covers have bungs I can use for breathers
2020 ZL1LE A10.
Old 09-12-2024, 06:03 PM   #22
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I'm still betting on a loose filter, loose cooler bolt, or loose pan bolt
Mods being installed-
Old 09-12-2024, 06:49 PM   #23
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Yep, I’ve been running the -12AN line with my MM Wild from day one. We’ve had LOTS of “learning experiences” in regards to boost and fueling lol… still using an LT1 front seal and OEM rear main with no issues at all… We definitely would have popped one if we didn’t have this setup. <furiously knocking on wood>
Old 09-12-2024, 06:58 PM   #24
JSH
JSH's Avatar
Drives: '20 ZLE
Thumbs down
I'm going to put a metco on it
2020 ZL1LE A10.
Old 09-13-2024, 07:50 AM   #25
KingLT1
KingLT1's Avatar
Yeah I meant -12 just to clarify.
It should work.
Old 09-13-2024, 07:58 AM   #26
JSH
JSH's Avatar
Drives: '20 ZLE
It should work. Or swap all your lines to -12.
As you see here, each valve cover has two -10an breather provisions front & rear on the valve covers. The CC is connected to the rears, and LME says to use the fronts for crankcase breather caps. LME used a complete LT rear cover with seal.
2020 ZL1LE A10.
Old 09-13-2024, 01:19 PM   #27
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Looks to me like you need to upgrade the line that goes from the intake to the PCV junction box. This will help evacuate crankcase pressure with vacuum. I went with the JRE kit he sells that comes with a 5/8 hose and fitting.
Edit: The Big Gulp should have came with 3-4 fittings total with the intake. You end up using the one with a 5/8 barb. That will be one six pack of Three Floyd’s Zombie Dust.
CamOnlyJabroni is offline   Reply With Quote
Old 09-13-2024, 04:04 PM   #28
JSH
JSH's Avatar
Drives: '20 ZLE
This line? https://jannettyracing.com/products/...40696118116375
2020 ZL1LE A10.
