Old 06-15-2024, 08:43 PM   #15
beworthy3
beworthy3's Avatar
Drives: 2018 Camaro SS 1LE
Originally Posted by DaveC113 View Post
Pad taper is very common, and probably worse on oem pods that get too hot. it helps to flip the pads between track days. I also switch between OEM (Ferodo HP1000) for street and autox and Ferodo 3.12 for track. Since both are Ferodo you don't need to rebed the brakes when switching, and once you get it down you can change pads really quickly. The 3.12s are $$$ bot worth it, they last a long time and performance on track is amazing.
I was just looking at rotors, I found DBAs w/o hats for just under $300 each if you don't mind reusing the hats, and $750 for OEM rotors with hats on amazon.
I will definetly start to flip pads. This was only the 3rd day on these pads so I was caught a little off guard.
Which DBA rings did you find? I looked but couldnt find any that cheap
beworthy3 is offline   Reply With Quote
Old 06-15-2024, 09:51 PM   #16
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Yeah, 3.12 are expensive but I have about 10 days on mine and will probably get a couple more, plus mu is much higher so you won't need to use as much pedal pressure.
Double check these will work, but I'm pretty sure they will... discount code "memorial24"
https://goturbo.net/dba52770-1ls-dba...ring-52770-1ls
Old 06-15-2024, 10:28 PM   #17
beworthy3
beworthy3's Avatar
Thanks for the code. Didnt work though lol. All good. I found some replacements that are decently priced.
I’ll have to think about getting the 3.12 pads. I think i just ran these pads down too long. Got 4 days out of my last set. This set was on day 4. The price for the 3.12 is hefty but might be worth it if you are getting 10+ days on them.
Old 06-15-2024, 11:46 PM   #18
RoaringV8
Drives: 2017 HBM Camaro SS 1LE Camaro
I've also experience pad taper as some pistons tend to hang more than others for whatever reason. I rotate my pads after events for this reason. Even after rebuilding and putting in vented pistons I still have this issue though it isn't all that bad. I've been using the EBC SR-11's recently and have been pretty happy with them. They are also pretty good on rotor life.
That amount of track days you have on those rotors is in line for about what I'd expect the life of the rotor to be.
RoaringV8 is offline   Reply With Quote
Old 06-16-2024, 06:21 AM   #19
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
One of the best features of the Gen6 Camaro on track is the brakes. But, that performance comes at a cost with the weight of our cars. I'm in the habit of a "brake service" every 2 days at the track.
- Pull wheels
- Remove and inspect brake pads, rotors
- Measure thickness of pad/rotors
- Clean calipers, pistons and pins with soapy water (dawn works best)
- Reassemble
- Minor chassis inspection
I also have switched to Cobalt pads, as while huge Ferodo fan, the cost is nuts and Cobalts are much cheaper with same or better performance.
Ken
khcoaching is offline   Reply With Quote
Old 06-16-2024, 09:39 AM   #20
beworthy3
beworthy3's Avatar
Yeah it looks like I’m going to have to start a system like this. I think doing the pocono mega course last month or what messed it up for me. That was my 3rd day on these pads. But the amount of corners and braking at that track probably wore them down at double the rate of a normal day.
Flipping pads is something I’ll start doing more often
Old 06-16-2024, 04:26 PM   #21
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
- Pull wheels
- Reassemble
Ken
Yup, pretty much my procedure after each track weekend. I measure the pad thickness and use a spreadsheet to calculate how the wear is occurring on each pad location (LI vs LO vs RI vs RO) as well as top or bottom so I can see how the wear taper is. Do this enough times and you'll see a common wear pattern which will help you decide where to rotate the pads to (pad with the most material on it gets rotated to position and orientation that tends to wear the greatest). Some may argue it's a bit overkill, but I've got an analyst mind and want to get the most out of the $ I'm spending on pads. I figure I'm getting at least an extra track day or 2 out of each pad set by doing this process.
N Camarolina is offline   Reply With Quote
Old 06-17-2024, 08:22 PM   #22
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
Are you guys flipping the rear pads too or just the fronts?
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 06-18-2024, 12:20 AM   #23
N Camarolina
I flip the rears also, but they don't tend to taper as much.
If you want to flip them, you'll need to cut off the screetch wear tabs as they won't slide into place (the inside if I recall) with the tabs on them. An angle grinder or Dremel cut off disc will do the job though.
Old 06-18-2024, 03:10 PM   #24
cdrptrks
cdrptrks's Avatar
Originally Posted by beworthy3 View Post
What the inside of the rotor looks like.
Slap a new set of pads in there and the rotor will clean up naturally and continue to work well on track assuming it is not below minimum thickness and there are no cracks to the inside or outside edges (especially check the inside from the back of the rotor where the rings bolt to the hats). I've done it multiple times when the rotors looked worse than that.
For SS 1LE normal (48 state legal) brakes, stock front rotors are 34mm thick new and 32mm is the minimum (discard) thickness.
Old 06-18-2024, 03:47 PM   #25
beworthy3
beworthy3's Avatar
I will measure the thickness tonight or tomorrow and will think about doing this. I thought somebody might tell me this is ok. I already have the new rotors so I might just change anyway
Old 06-18-2024, 04:12 PM   #26
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
time to hit up kns brakes and get some girodisc rings!
