#15 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Not sure where you got your info from but it's incorrect.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#16 | |
![]() Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M Join Date: Nov 2024
THANKS!!! There is a statement on the website install instructions to "see certain car's connection diagram". Do I take this to mean they will provide specific wires to connect to in some other install instructs NOT on the website? |
#17 | ||
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
2018 Blue 1LE- they do provide install instructions specific to your car. They show you which wires you'll need to hook to, and more importantly what those wires are. Ideally, you don't hook to the wires in an obvious place. You find another spot or spots in the car to access the signal wires you need so it's not in what I will call "an obvious location"
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#18 | |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
#19 | |
Thanks again!! |
