02-20-2024, 10:45 AM | #15 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
uh oh that's not good
GM Gen V Calibrator
02-20-2024, 11:44 AM | #16 |
Drives: 2022 camaro SS 1LE Join Date: Jan 2023
02-20-2024, 12:29 PM | #17 | |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
It may be completely random but you need to check fuel pump preload when you put it back together to make sure it isn't bottoming out the pump or running with a bunch of lash. Last edited by Katech_Mike; 02-20-2024 at 12:56 PM. |
02-22-2024, 01:26 PM | #18 |
Ok guys update, big huge thanks go out to everyone that tried to guide.and help me, mega aka Jason SBT, Kinglt1, Brett, and Katech Mike!!!! But he hit the nail on the head it was indeed my pump seals had failed just dumping raw fuel into the crankcase. I got out almost 14 qts and i only had put in 9 while breakin in the motor. So changed the oil 4 times in the last hour and then put in fresh oil and filter. New plugs, cleaned O2s, cleaned out the manifold and heads. New hpfp, pipes, and its back to running 100% an then some. Ended up after measurements the engine wanted a .060 shim. The guys that i had trusted to do it right when i was on vaca put in a .080 thus bottoming out the fuel pump and ultimately causin it to fail. Lesson learned .... just do my own wk noone will care for my car better than me. I have been trying to get Katech Mikes paypal as im a man of my word but he has thus far refused .... top notch guys there and a HUGE thank you to him and his team. He knows its his if he wants it.
02-22-2024, 03:05 PM | #19 | |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
Glad you were able to figure it out and props to Katech Mike for calling it. |
02-22-2024, 04:18 PM | #20 |
Mike is the man!
02-22-2024, 04:41 PM | #21 |
Props the Mike! He probably has seen this a time or 2.
2016 NFG 1SS A8
04-07-2024, 09:31 PM | #22 | |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
What is the procedure to check the pump preload?
