Old 11-29-2023, 01:18 PM   #15
Deacon Blues
Drives: 2024 Camaro 1SS M6
Originally Posted by Jetrep View Post
the auto lock / un lock feature (I think this is the name for it) is where you can walk up to your locked car with the key fob in your pocket and push the silver button on the handle to un lock the car.
the relay attack uses a computer to fool the car that a bad guy is holding a key fob. This setting can be disabled in where you need to push the un lock button on the key fob to unlock the car.
Is this something that can be disabled in the vehicle settings? I thought I remember someone doing this by removing the door trim and disconnecting some of the wires. I'd prefer to have this off but would also not like to go meddling about in the trim if I don't have to.
Deacon Blues is offline   Reply With Quote
Old 11-29-2023, 01:23 PM   #16
Evergreen6
Drives: 2023 Camaro 1SS
Yes, it's called Passive locking/unlock. It's in the setup menu on the infotainment sceen, at least on my 23 it is.
Evergreen6 is offline   Reply With Quote
Old 11-29-2023, 01:50 PM   #17
Deacon Blues
Awesome, thanks!
I've been thinking of a quick disconnect for the battery as a killswitch, but I'm wondering if it will cause more issues with having to relearn every time. I feel bad for y'all who have to deal with this issue as a daily driver, I think I'd go nuts. I don't typically take the Camaro out unless I'm not going to park somewhere or I can see it from where I'm parked, but I know that isn't the typical use case.
Old 11-29-2023, 01:51 PM   #18
Rogueleader_92
Drives: Chevy camaro, Chevy cruze
I did this myself but it doesn't stop the real issue of a relay attack, they can still break the window, jump in and using the relay attack start the car. Sure, it's a lot noisier but at 2 am the time it would take me to wake up, recognize the sound of breaking glass and/or it being my alarm gong off, get out of bed with my bedside high velocity lead thrower and make it out to my car they could easily have the car gone.
Final solution is a faraday box/pouch to keep my fobs in when not in use.
(Previous, totalled, hit from behind 8/2023) Black 2010 Camaro 2LT, RS. 82K miles.
Blue 2023 Camaro, 3LT, RS.
Rogueleader_92 is offline   Reply With Quote
Old 11-29-2023, 02:03 PM   #19
Deacon Blues
Bought a couple of those once I had the dealer hold the car. I tested them and they do work (I was a little skeptical). These were the ones I bought, the small ones fit the '24 fob well: https://www.amazon.com/Protector-Blo.../dp/B0B4DCLY87
Old 11-29-2023, 03:00 PM   #20
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Awesome, thanks!
Right way to do it is a kill switch for the fuel pump.
Christian1LE is offline   Reply With Quote
Old 11-29-2023, 04:20 PM   #21
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Originally Posted by CalgaryZL1 View Post
I’m just wondering if anyone did fuel pump or starter cut off switch hidden in the cab and if so how they went about wiring it? Like at the pump/starter or at the fuse box. I haven’t found any good info on the 6th camaro specifically
I am hoping arpad_m will have some insight on my question
Old 11-29-2023, 06:50 PM   #22
Sorry, brother, I would've helped and understand why you're asking, but this one isn't something I have or, frankly, I'd want to install...
Old 11-29-2023, 07:19 PM   #23
CalgaryZL1
CalgaryZL1's Avatar
I am Just looking for a simple short term bypass for any one of the two systems, for example going to the local hardware store or anywhere else for an hour or two where I could fall pray. A relay bypass of sorts. Our two Alberta capital cities Calgary and Edmonton are getting hit hard with vehicle theft lately.
Old 11-30-2023, 07:15 AM   #24
ember1205
Hot Camaro
ember1205's Avatar
Originally Posted by FlukeSS View Post
But as mentioned Onstar can track, manage electrical, and disable your car if it is stolen
And one of the first things the thieves do is rip out the OnStar components or kill the power to it. Their ability to track and 'control' the car works well for when your teenager doesn't come home by curfew. But a thief will have it disabled before they leave your driveway.
Old 11-30-2023, 07:46 AM   #25
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Looking for a kill switch? You can always put an inline on/off switch on the stater fuse. Pretty easy to with under the hood fuse box or put the on/off switch to one of the wires going to the push button starter button. I would recommend just doing the ground wire so no power going thru your on/off button.
Below is location video of fuse relay and fuse for starter. Chose your location, I would imagine you would get tired off opening your hood ever start but it would defeat the thieves trying to start your car electronically.
https://youtu.be/WTQu9U5JXCo?feature=shared
Below video for push button start button.
https://youtu.be/dYfkLRU6hJQ?feature=shared
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 11-30-2023, 08:18 AM   #26
https://www.camaro6.com/forums/showt...9#post11384179
Old 11-30-2023, 10:57 AM   #27
Rogueleader_92
Originally Posted by MSS1LE View Post
Is that the same as my cordless long distance hole puncher?
Well I'm not talking about a wrist rocket...
Old 11-30-2023, 11:03 AM   #28
CalgaryZL1
CalgaryZL1's Avatar
Thank you very much for the info!
