Old 11-12-2023, 09:38 AM   #15
HemiDave
HemiDave's Avatar
Drives: ZLE/DEMON/GLADIATOR/GSXR1000R/ZX10R
Originally Posted by grampa_ss View Post
Another option: Been using since 2017
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Yup.
This is all you need.
2018 Dodge Demon #1399
2020 Jeep Gladiator Rubicon 6 speed manual
2023 ZL1 1LE 6 speed manual
2018 Suzuki GSXR 1000R
2021 Kawasaki ZX10R
HemiDave is offline   Reply With Quote
Old 11-12-2023, 09:54 AM   #16
Jus Cruisin
Old Gearhead
Jus Cruisin's Avatar
Drives: 2023 GMC Sierra Denali Ultimate
Originally Posted by HemiDave View Post
I have been using Deltran 12V Battery Tender JR for years for my motorcycles and cars in NY.
Attach it and forget it.
Zero issues with my batteries since.
The same tender works perfectly for motorcycles and cars.
Don't let the small size fool you.
I have the "Plus" now but I've had a Jr before. Answers the OP's question perfectly. I've used a Battery Tender on hot rods to classic muscle to new stuff. I lived about 10 miles from the Deltran plant in Florida. Built in the USA
2023 Camaro ZL1 convertible - black - SOLD
2025 GMC Sierra Denali Ultimate - black - 3.0l diesel
1937 Ford Slantback
Jus Cruisin is offline   Reply With Quote
Old 01-17-2024, 10:54 PM   #17
Transformerrk
Transformerrk's Avatar
Drives: 2023 ZL1 1LE, 2010 SS Transformer
Originally Posted by Rock-It Man View Post
This is what I have used since 2010. First on the 2010 SS, now on the 2023 ZL1.
hey, nice to meet you! I just happen to have a 2010 SS and a 2023 ZL1 too!
looking for tenderers
is the 12V 1.25 AMP one you sent link to enough, or do I need one that also charges?
Thanks,
rob
Transformerrk is offline   Reply With Quote
Old 01-18-2024, 07:53 AM   #18
OBD3
Drives: 2023 Chevrolet Camaro 2LT RS trim
On my 23, i use the 10 amp Noco, which i like as its waterproof, I usually plug it in every two weeks for a charge as my poor vehicle is under cover in 3 feet of snow. Mine is also hardwired to the fuse jump points on the front of the vehicle.
OBD3 is offline   Reply With Quote
Old 01-18-2024, 08:24 AM   #19
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Did this a few years ago and it’s great. No problems what so ever, plug it in and battery is always top up with power. Below link is the install info.
https://www.camaro6.com/forums/showthread.php?t=587831
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 01-18-2024, 08:51 AM   #20
GreyGhost702
Drives: 2019 Camaro 1SS1LE
That's slick. Best part, you can troll on-lookers and tell them you ditched the V8 and converted to electric.
I use https://www.harborfreight.com/4amp-f...ner-63350.html for all my maintainers. If you catch them on sale, they're $30. You can find similar on Amazon for a bit less, but I don't know if I'd trust the guts. I use these on my RV dual deep cycles, my dirt toys, generators, cars/trucks. Just plug it in and go, it detects battery type and runs cycles on the battery so it doesn't just sit at top voltage for long periods. Not sure if it actually helps with sulfating but I got tired of short lived batteries that I used standard trickle chargers on.
GreyGhost702 is offline   Reply With Quote
Old 01-18-2024, 09:00 AM   #21
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
I like this 5amp, but you could also just use the 1amp version. Haven't seen that socket extension part before, wonder what size hole you need for that. <found it, 2 inch hole>
2022 CAMARO LT1 COUPE AT10
fj5gtx is offline   Reply With Quote
Old 01-18-2024, 12:38 PM   #22
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
CTek. Look at who they are OEM for, and you'll get one too.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 02-02-2024, 04:38 PM   #23
DEADBYDAWN
DEADBYDAWN's Avatar
Drives: Chevy Camaro 98Z
That is very cool.
I have a 4th gen and it had a optima red top in it. I bought a battery tender + and the clamps on the battery tender + melted where they were connected. I contacted customer service and was told I needed to use the circular connectors. I unhooked my cars +&- because I was a bit concerned about the cars computer. Within a month the circular connectors had a bunch of white acidic buildup on them. I cleaned it off and it happened again. It was like the charger never shut off. Ruined my red top. I knew something wasn’t right when the chargers clamps melted.
Anyone know why Chevrolet doesn’t have battery chargers/tenders for the 2024 SS?
DEADBYDAWN is offline   Reply With Quote
Old 02-03-2024, 12:07 AM   #24
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
This is what I use, I've used it for the last two years. I'm still running my original battery. If you are truly using it for trickle and not to charge a dead battery, this is all you need. There's no reason to put more amps into it.
https://www.autozone.com/test-scan-a...ahd/614699_0_0
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 02-03-2024, 05:33 AM   #25
NashZL1
Drives: 2022 Camaro ZL1
I have four DELTRAN Battery Tender 3 Amp chargers.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2018 Porsche 718 Cayman GTS
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2024 Honda Civic Touring
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
