Old 10-31-2023, 02:22 PM   #15
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by LORDOBERON View Post
those supercharged covers are sweet!!. you have a link to them
They're in my garage for sale.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-31-2023, 03:15 PM   #16
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Those look bad ass also!
Agreed! Mike from TooHighPSI is a sharp dude and not afraid to chime in on this board with knowledge beyond most of us mere mortals haha
And to be clear, I love Katech! I’ve been running their VVT front cover, AFM valley cover, 112mm TB, custom TB adapter for the new Whipple, etc and their stuff is first class. Great support too.
Old 10-31-2023, 09:02 PM   #17
Crusher Camaro
Drives: 19 ZL1
I went with the Motion Raceworks valve covers and catch can setup when I did my cam swap.
Like the look with the black Whipple.
dont have any great shots of them, here is engine out and during whipple install while routing wires and cleaning up the mess.
Only issue, had to make a little bracket for the dipstick to bolt to, not an exact fit for the stock bracket.
Crusher Camaro is offline   Reply With Quote
Old 11-01-2023, 06:08 AM   #18
Smokin19
Drives: 19' ZL1 A10, w/pdr
My baffled WeaponX vlv covers. They can do any engraving or color you may desire.
Smokin19 is offline   Reply With Quote
Old 11-01-2023, 09:37 AM   #19
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
I've always loved the look of the Weapon-X valve covers! Nice add!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 11-05-2023, 06:10 PM   #20
45LongColt
45LongColt's Avatar
Drives: 2018 Zl1 Camaro
I too ran with Katech covers but slightly different setup.
Big Gulp|NW103|SW Headers|UHO CATS|XPipe|Borla Atak|MM CC|Kong Ported|NSX|ATI Damper|DSX 9.45 Lower|ZPE 2.5 Upper|DM Tensioner|FW Green Belt/BTR Gen V LT4 Cam w/32% lobe/BTR VVT Lockout/Pratt & Miller Chain/BTR Pushrods,Valve Springs, Retainers, Hydraulic Lifters & Guide Plate, Trunnion Roller|Katech Valley|KaTech Valve Covers|MSD Coils|DSX E Sensor & Aux Pump|ICT Water Pump|Katech Oil Pump|Cordes & Mishimoto Expansion Tanks|P3 Gauge|LC-2 Wideband Sensor|KaTech Wires|DynoJet Tuned
45LongColt is offline   Reply With Quote
Old 11-05-2023, 06:21 PM   #21
45LongColt
45LongColt's Avatar
Better pic of the covers.
Old 11-05-2023, 06:59 PM   #22
JSH
JSH's Avatar
Drives: '20 ZLE
I don't get it. Why dress up the underhood when you're the only person who sees it?
2020 ZL1LE A10.
Old 11-05-2023, 07:59 PM   #23
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I do it because I have six months of winter storage to install and admire what’s under my hood
Old 11-06-2023, 04:58 AM   #24
Smokin19
Why put all those performance parts on the car when you are the only one who can feel it.
Old 11-06-2023, 11:42 AM   #25
45LongColt
45LongColt's Avatar
If your going to build out your motor, install new internal components, increase your performance to it, it only makes sense that those parts come in a variety of nicer looking styles/colors. Most folks don't just swap out value covers, its usually part of a build and the original covers were ugly as hell, so replace them.
Old 11-06-2023, 12:10 PM   #26
clg82
Drives: 2020 Camaro ZL1
These are the Katech Cast Valve Covers... I think they are the best looking on the market, but they require the following...
1. Coil Relocation Kit (no brainer)
2. Re-Plumb PCV Hoses as the connector locations change.
3. Install a MM Wild CC (also a no brainer) IMO
4. Using a restriction fitting on the clean side of the CC as the Katech cover have no baffling.
In short, this is not an easy transformation for some... but for me, it was 100% worth it!
CHP: "Pop your hood, let me take a look", SOCAL "ummmm, no?"
Old 11-06-2023, 06:48 PM   #27
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
That's assuming they could catch me
