Old 01-22-2010, 08:12 PM   #15
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by SleepWarz View Post
I'd say you folks have enough 'nucks' to cause an eartquake =p
Or just ask part of your population to all jump up at once.......
HOLY CRAP YOU DO HAVE AN EARTHQUAKE WEAPON!
There were also stories that it was caused by a French nuclear weapon ...
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 01-22-2010, 08:18 PM   #16
Oddball
Oddball's Avatar
Drives: attentively
Does anybody remember the name of the fault that runs under Missouri?
Oddball is offline   Reply With Quote
Old 01-22-2010, 08:46 PM   #17
DGthe3
Moderator.ca
DGthe3's Avatar
New Madrid
Old 01-22-2010, 08:55 PM   #18
Oddball
Oddball's Avatar
Drives: attentively
Originally Posted by DGthe3 View Post
New Madrid
Thank you.
Can you imagine the effects a 7+ magnitude quake would have on that region?
Old 01-22-2010, 10:00 PM   #19
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Thank you.
Not as bad as Haiti. We have things called 'Building Codes'
Old 01-25-2010, 12:03 PM   #20
2001ragtop
2001ragtop's Avatar
Drives: V8 american car
Hahahahahah
If we had an "Earthquake Weapon," we wouldn't have aimed it at Haiti.
Hell, if we had an "Earthquake Weapon," Chavez wouldn't be able to make a statement at all.
i don't want to even know what kind of weapons exist these days. hopefully that one is truly imaginary
2001ragtop is offline   Reply With Quote
Old 01-25-2010, 12:36 PM   #21
Brokinarrow
Brokinarrow's Avatar
Drives: 2012 Honda NC700x
Originally Posted by drivingincamaro View Post
a 5.0 is way less worse then a 7.0 , 7.0 I remember hearing about how much points you go up it increases by a lot
Richter scale increases in an exponential manner (regarding power of the quake). http://en.wikipedia.org/wiki/Richter_scale
Brokinarrow is offline   Reply With Quote
Old 01-25-2010, 01:51 PM   #22
reddevilseye
reddevilseye's Avatar
Drives: rs/ss
one question, why dominican republic didnt feel anything?? its 7+ god dam it its not 4 or 5
theres something fishy and we can cause that and we need to test its effect some where and islands are the easiest to do so, we have all the tec to do so, subs drills and bombs,
its like the bio weapon program that when the public new about nixon was forced to cancel it and tell all ppl its gone, but 1992 in iraq who used it???? we did and we still work on it, there is no need to let you or me know what they r doing
reddevilseye is offline   Reply With Quote
Old 01-25-2010, 02:05 PM   #23
Brokinarrow
Oh, its oook, just go back in the corner and put your tin foil hat on, mm k?
Old 01-25-2010, 02:10 PM   #24
Brokinarrow
And to further prove your craziness, read red text below:
one question, why dominican republic didnt feel anything?? They did, if you payed any attention to the news, they said the quake was felt in the Dominican Republic and Cuba, but no damage was caused
its 7+ god dam it its not 4 or 5 '7.0-7.9 Major Can cause serious damage over larger areas.' Thats off of the wiki link I included Over large areas, and as it was a 7.0 that range probably only extends 25 miles or so
its like the bio weapon program that when the public new about nixon was forced to cancel it and tell all ppl its gone, but 1992 in iraq who used it???? Ok, what the crap are you talking about here? we did and we still work on it, there is no need to let you or me know what they r doing
Again, go put on your tin foil hat.
Old 01-25-2010, 02:23 PM   #25
reddevilseye
Drives: rs/ss
i dont need to,if we learned one thing in the past 100 years is that we can do what we think is imposible or just gods work
http://www.guardian.co.uk/world/2009/may/25/north-korea-hiroshima-nuclear-test
this is the resent north Korea test caused 4.5 earthquake,the thing is posible to be made,
or someone was testing his new camaro its also posible
Old 01-25-2010, 02:43 PM   #26
Brokinarrow
yeah, but a 4.5 isn't anything but your shelves shaking a little bit. So setting off a more powerful nuke may indeed produce a more powerful earthquake. But if that was the case here, it would have been detected. This quake's epicenter originated 5 miles below the surface of the Earth.... not exactly a depth we can drill to. Again, if you pay attention to the news it was stated that this area was overdue for an earthquake as it sits on a MAJOR FAULT LINE.
Now, I'm not saying you should blindly accept everything the media says (as that would be unwise), but there are enough different sources stating this that I can accept the findings.
Old 01-25-2010, 03:58 PM   #27
DGthe3
Moderator.ca
DGthe3's Avatar
At the surface, the energy released in an 7+ magnitude earthquake is equivalent to a very large nuclear bomb, equal to the largest ever detonated. However, there is currently no known method to release all that energy in the form of a shockwave. In a nuclear explosion its released mainly as heat. Super-secret doomsday weapons are pure science fiction, with emphasis on fiction. An earthquake weapon would be dependent upon the discovery some way to first generate the waves (like the discovery of nuclear fission led to the first nuclear bombs). On top of that, if it was a test of an earthquake weapon why not target it against an unpopulated pacific island instead of a poor nation with millions of people? It just makes no sense.
And the notion that it was a nuclear detonation, buried deep underground is equally preposterous. First, it would need to be several times larger than the largest nuke ever detonated because its underground. And second, someone would have made a huge announcement. Most highly developed nations can detect earthquakes and nuclear explosions (even underground ones) and know the difference between the two. Using a similar line of thought, the Soviets indirectly proved that the Apollo moon landings were not a hoax ... they could intercept the radio transmissions coming from the moon and would have said something if things didn't match up.
Old 01-25-2010, 04:32 PM   #28
Brokinarrow
Now THAT i hadn't heard before Good stuff right there.
Just a thought. v6sonoma Tuning / Diagnostics -- engine and transmission 2 08-07-2009 12:32 PM
Horrible Brake Squeal Paperer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 07-27-2009 12:35 PM
Customer Complaint thread Hylton Camaro Price | Ordering | Tracking | Dealers Discussions 1299 07-23-2009 01:20 PM
I thought this was funny so I thought I would share. Sierra Off-topic Discussions 15 05-19-2009 05:38 PM
