Old 10-23-2023, 03:17 PM   #15
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by Kerry View Post
Adding a jms booster epically if u dont need it can reduce reliability if u tune to depend on it. One more thing to fail. If u dont need it dont use it.
Voltage boosters 100% does not reduce reliability of the pumps.
They are not connected to the pumps they are connected to the FSCM.
Higher voltage supplied to the FSCM reduces duty cycle at the pump by up to 40%
Electric fuel pumps run cooler at lower duty cycles and run faster at higher voltage.
There is more time to cool between pulses when you are less than 100% duty cycle.
100% duty cycle means on for 1 off for 1,
50% duty cycle means on for 25% off for 75% hence more time to cool.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 10-23-2023, 04:22 PM   #16
grampa_ss
grampa_ss's Avatar
My .02. I've been runing Meth since 2018. It has never failed. Pump did started leaking after a year and was replaced under warranty...(but it was still functioning). I also have hundreds of WOT pulls. Like Kerry....my failsafe is IAT temp.
Old 10-23-2023, 07:10 PM   #17
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
You and me both, I'm lost on the post...
Seriously, what is the point of the original post? Is there a new failsafe you implemented or something, Kerry? Or is this just a thread to promote the use of meth injection? I'm still lost.
Mods being installed-
Old 10-23-2023, 10:21 PM   #18
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Im not trying to promote it or sale it it just something I came up with. I have not seen anyone do it but u would think it would be widely known and maybe it is. I was just kinda excited to make it actually work its really pretty simple and its not really my creation but something i had been thinking building then found that most of it had already been built so that seat me off to complete it and make it work for the camaro or lt1 I guess it would work on the zl1 corvette or i guess the lt1 dont know about others but probly would.
Everyone is just so down on meth and it is possible for it to fail just like anything else. So its nice to have that peace of mind and honestly with a car making the kinda power mine is, looking at a afr gauge is not where your attention should be for sure.
I have 3 setups now the one I just did, and car is so dependent should it stop it would fall on its face, and the old temp thing.
But what if it partially stopped like one nozzle stopped up or something, then what. Thats where this system would come it to play.
I was just excited about it.
Cool! I still must have missed what the system IS though. Is there something that used to be in your first post that isn't anymore? I don't see pictures, a link, an explanation, nothing. Will someone please explain what I'm missing here? Lol. I can't be THAT forum illiterate.
Old 10-24-2023, 07:46 AM   #19
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
Super cryptic new invention, that's already been invented and used. Might be smoking it instead of spraying it...
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
Old 10-24-2023, 08:24 AM   #20
ramairroughneck
Drives: 2018 Camaro SS
I just ordered a new Prometh pump. My pump isn’t bad and has never leaked but I am changing it due to it being 5 years old and it being on 100% methanol. I am considering switching to a water ethanol mix for a little cooling and it being less corrosive. To the OP, if you do decide to run methanol, do a trunk tank. It will keep your pump out of the elements. You won’t have water running into the pump. Mount your pump horizontally. You don’t want a methanol leak going through the cracks of the pump and seazing the bearing. I can’t stress enough to always check your tank level. Test the system before every drive and make sure you feel the car stumble and go rich on your AFR gauge. If it doesn’t go rich do not go wide open throttle. Check your pump for leaks often, use braided stainless line, not the cheap plastic stuff that can melt or rub through causing a fire. Lastly, pull your jets every six months and drop them in an ultra sonic cleaner, take them apart and run a fine speaker wire through the orifice. It’s something that you must always be mindful of. I’m in the camp that it could go at any moment. I’ve had a good run but I’m always thinking about it. With bigger injectors and port systems out there now I would consider those before going this route again. It’s great and makes power but that comes with major responsibility
ramairroughneck is offline   Reply With Quote
Old 10-24-2023, 09:41 AM   #21
grampa_ss
grampa_ss's Avatar
Can you elaborate the new failsafe system you're using? We're all curious.
Old 10-24-2023, 09:56 AM   #22
JANNETTYRACING
One of the systems we have used is a pressure sensor just before the nozzle that communicates with the Alky controls box
Then tie it to the boost controller (turbo application) and set it to run in scramble mode aka Higher boost when pressure is present, and dump the scramble mode if pressure drops.
In a PD application, you could combine this with a smooth boost, you can possibly dump boost when no pressure is present.
Or use it to dump pressure to bypass valve and let it open.
I have come up with hundreds of different solutions over my career but don't always find time to market them.
Old 10-24-2023, 10:38 AM   #23
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Love that solution TED...!!!
Old 10-26-2023, 09:40 AM   #24
grampa_ss
grampa_ss's Avatar
@Kerry (OP). Where did all the info go? You posted a lot of information yesterday and now it's gone.
Old 10-26-2023, 09:42 AM   #25
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Kerry, did you not win at that particular casino after all?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 10-26-2023, 10:57 AM   #26
VanillaGorrila
Drives: Chev Camaro 1le
Don't do meth kids LOL
VanillaGorrila is offline   Reply With Quote
