#15 | |
![]() Drives: Chevy Camaro ZL1 Join Date: Sep 2023
#16 | |
#17 | |||
Alas, I haven't been able to personally try the Nittos yet, hence my deferral to others in the forum. Quote:
The alternative to this is the full ZL1 1LE aluminum bushing kit from GM (see here), but that kit, if even available these days, is more expensive, much more tricky to install and might increase your NVH. The BMR lockout kit will give you 90% of the stiffness advantage (check out their underbody cam video).
#18 | |
![]() ![]() Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
A.Bushing kit, differential lockout, aluminum. B. Bushing kit, rear cradle, lockout. C. Cradle brace, front of rear cradle. D. Lower trailing arms, non-adjustable, poly bushings. E. Upper trailing arms, non-adjustable, poly bushings. F. Upper control arms, non-adjustable, poly bushings and then an alignment. I bet if I just swapped to stickier tires, too, this would be perfect - more than enough traction for the stock power level.
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2024 Audi RS3 2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
#19 | |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
#20 |
It's not bad, but you will definitely notice more noises coming from the rear when you're driving very slowly, or over bumps, for example thru a parking lot.
#21 |
![]() ![]() Drives: 2019 2SS Camaro Join Date: Apr 2012
#22 |
![]() Drives: 24 Sliverado 1500 ZR2, 2017 ZL1 Join Date: Feb 2021
WD-40 is never a good long-term solution. Try Tri-flow
Finally on the way to 1K.....
#23 |
It's not really squeaking, per se...more like clanking and clunking
#24 |
Or Drislide, it works very well for me. I use it to lubricate the NPP valves, and it lasts much-much longer than WD-40 on household door hinges, for example.
#25 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
YOu will have an increase in NVH but only if your install is foul will you get noises that you need to remedy. The rod ends BMR uses are teflon coated, if that helps. But my problem was their sway bar that has a bit missing from the install. It's not enough to set an adjustable link to the OE length and just press play. I would have the instructions read, yes, OE length as a start point, but then maintain the bar arms parallel or level or close to it, and RAISE the links is/as needed and keep the link and arm geometry at or close as you can to 90 degrees.
I had alot of noisy clunky crud in the rear of the car with the links short and the bar arm pulled down to the link. Also, they make no mention of the bar needing to move freely in the frame mounts. If the mount is so tight that the bar cant move in it's arc, you'll have a bad problem. They need to address that and that using a washer under the lower bolt can free it up. Of my sway bar, the cradle lockout, and the front cradle braces, those problems were 99% of the BS NVH I had on the install. Fixed everything and the performance is greatly inproved, as expected. Rear stays planted on WOT pulls. |
#26 |
![]() Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
From my understanding when you want the biggest, baddest tire period there's only one way to go, Mickey Thompson drags radials SS street tire for straight line, capable of 8 seconds in the quarter and will hook in low 50 degree weather or lower. According to shops like LMR Houston, I'm getting a set for my chevelle myself. I don't know if they make a 20 inch tire, but a 18 inch is available.
#27 | |
Does yours put that power down pretty well? |
#28 | |
It's scary fast, just a little bit more than what I feel I can easily "tame", which is exactly what I wanted---the moment I stop respecting the car's power and let my guard down is when I'll make a stupid mistake. A lesson I unfortunately learned the hard way three years ago. In other words, I know my place and enjoy the HECK out of this amazing car with my current mods.
